Moving To New Servers!
Members interested in helping test the new NPORA server platform, please contact RedPath88 via PM or email for further information.
Thank you,
SAS and engine swap WD21
  • Please log in to reply
89 replies to this topic
#81 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 896 posts
  • Local time: 07:53 PM
  • Country:
  • Model:SE
  • Year:1992
Posted 13 August 2017 - 08:09 PM
The problem is with two letters, GM.
That's all I've got.
#82 OFFLINE   daver123
daver123
  • Topic Starter
  • Members
  • PipPipPip
  • 184 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 13 August 2017 - 08:46 PM
Fair enough. I'm looking at newer pumps than the stock 95 Pathfinder unit. I think the 2004 and older XTerras have a possible donor. They still use a similar PS box to the original Pathfinder ones and their PS pumps might be a good match, possibly new and improved too.
#83 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 896 posts
  • Country:
  • Model:SE
  • Year:1992
Posted 13 August 2017 - 09:10 PM
I thought the first gen x and wd21 had the same pump, just in a different spot.
#84 OFFLINE   Slartibartfast
Slartibartfast
  • Members
  • PipPipPipPipPip
  • 4,524 posts
  • Country:
  • Model:SE
  • Year:1993
Posted 13 August 2017 - 10:50 PM
What fluid are you running? I know Honda pumps don't work right without their own eleven-herbs-and-spices PSF, maybe GM's the same way. I know both of my friend's 4.3-powered rigs leak take PSF rather than the ATF the WD21 specs. Or, like you said, could just be a flow thing; maybe the Saginaw box that pump was built for has bigger guts and requires greater volume but lower pressure than the Nissan box.
I read on here that 94+ OE pumps were better, looks like you found that thread too. I got curious and had a look at some FSMs to see what the power steering pressure is supposed to be. Full lock, engine idling:
'89 Pathy: 1,109-1,194 PSI
'95 Pathy: 1,109-1,194 PSI
'97 Pathy: 1,251-1,337 PSI
'01 Xterra: 1,095-1,209 PSI
'03 Pathy: 1,251-1,337 PSI
Interesting that '89 and '95 are the same, given the other thread. Maybe they differ in flow, which I see no mention of in the manual. Either way, looks like an R50 pump should be an upgrade. Might even come with a ribbed pulley to match the serp I assume your 4.3l is running.
Looking at this thread on Pirate, I'm also seeing some Saginaw P-boxes with higher numbers.
#85 OFFLINE   Cuong Nguyen
Cuong Nguyen
    Mr. RTI
  • Members
  • PipPipPipPipPip
  • 2,306 posts
  • Local time: 09:53 PM
  • Model:XE
  • Year:1993
Posted 16 August 2017 - 01:17 PM
Funny, I converted to an xterra pump based on what Nissan nut's experience. Hoped it was worth it. I did take pictures of the internals between the two for comparison which can be found on photobucket
Sent from my SAMSUNG-SM-N920A using Tapatalk
#86 OFFLINE   daver123
daver123
  • Topic Starter
  • Members
  • PipPipPip
  • 184 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 19 August 2017 - 08:54 PM
I was doing some parts research on rock auto and it would seem that the 04 and earlier Xterras use a very similar steering box to the first gen pathy's. The r50 uses rack and pinion, not sure how different the flow and pressure requirements are.
That or just dig up a 95 pathy ps pump. just thought it would be better to try and rob a newer pump from a 04 xterra.
Good thread on pirate4x4 though, I just think I trust the nissan pump more than trying to make a gm pump play nice with the stock steering box.
#87 OFFLINE   daver123
daver123
  • Topic Starter
  • Members
  • PipPipPip
  • 184 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 19 August 2017 - 08:56 PM
I would like to see those pics but photobucket is dead to me.
#88 OFFLINE   Cuong Nguyen
Cuong Nguyen
    Mr. RTI
  • Members
  • PipPipPipPipPip
  • 2,306 posts
  • Model:XE
  • Year:1993
Posted 20 August 2017 - 05:56 AM
Here is the link: http://s2.photobucke...wersteeringpump
The truck could really benefit from power steering cooler. The reservoir gets really hot that I can't even touch.
#89 OFFLINE   daver123
daver123
  • Topic Starter
  • Members
  • PipPipPip
  • 184 posts
  • Country:
  • Model:SE
  • Year:1995
Posted 20 August 2017 - 08:29 PM
Good reference material. I think I am definitely going to track down an Xterra pump, and get a cooler. Just need some money and time. Maybe next month...
Do you know which year you got yours from and how many grooves on that serp pulley? The 4.3L is 6 groove.
Edited by daver123, 20 August 2017 - 08:35 PM.
#90 OFFLINE   Cuong Nguyen
Cuong Nguyen
    Mr. RTI
  • Members
  • PipPipPipPipPip
  • 2,306 posts
  • Model:XE
  • Year:1993
Posted 21 August 2017 - 08:21 PM
I have no idea how many grooves. I'm guessing 5. The VG33 guys could help you out.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
