shortysmash Posted January 28, 2011 Share Posted January 28, 2011 Well i went to advance to get some fresh gear oil for the old girl and they asked what type diff i had. I wasnt sure if it was limited slip or just a regular diff. So i didnt buy any since i know that limited slip diffs also require the additive. does anyone know how i tell and how much and what weight gear oil i should buy? i know to fill it up till it runs out fill plug, but any idea how many quarts that is i searched but found a couple differnt numbers Link to comment Share on other sites More sharing options...
MY1PATH Posted January 28, 2011 Share Posted January 28, 2011 Buy 3 qts of anything that says 70w90 or 8w90 and LSD on the bottle. No additve needed. Works in both types of diffs. anyway there should be a little orange LSD sticker above the plug (under the dust an mud) Link to comment Share on other sites More sharing options...
pathfounder Posted January 28, 2011 Share Posted January 28, 2011 I think I used something like two bottles when I did mine. Buy three and return one unopened. You should be able to tell if you have LSD or not just by driving through mud or gravel with some heavy throttle. Link to comment Share on other sites More sharing options...
MY1PATH Posted January 28, 2011 Share Posted January 28, 2011 or jack up one wheel (neutral no brake) and try to turn it. If it turns you are open if it doesn't you have lsd Link to comment Share on other sites More sharing options...
accurrate1 Posted January 28, 2011 Share Posted January 28, 2011 anyway there should be a little orange LSD sticker above the plug. My comes with it when I bought it, was just curious and went to check, sure enough my has little orange LSD Sticker. Link to comment Share on other sites More sharing options...
WOT Posted January 28, 2011 Share Posted January 28, 2011 (edited) Mine used just over 1.5 liters I went with royal purple synthetic for my non lsd diff Edited January 28, 2011 by WOT Link to comment Share on other sites More sharing options...
shortysmash Posted January 28, 2011 Author Share Posted January 28, 2011 Buy 3 qts of anything that says 70w90 or 8w90 and LSD on the bottle. No additve needed. Works in both types of diffs. anyway there should be a little orange LSD sticker above the plug (under the dust an mud) Is that supposed to be 8w90. isnt there a big difference between 70w90 and 8w90. Link to comment Share on other sites More sharing options...
pathfounder Posted January 29, 2011 Share Posted January 29, 2011 use 80 90 Link to comment Share on other sites More sharing options...
Panbacca Posted February 2, 2011 Share Posted February 2, 2011 (edited) There was a Valvoline brand that I used in mine that was recommended for both LSD and non-LSD. Works like a charm! I used 80w90, and buy yourself a couple of bottles. That should do it fine. Edited February 2, 2011 by Panbacca Link to comment Share on other sites More sharing options...
rig002 Posted February 16, 2011 Share Posted February 16, 2011 Hello guys, Ok I have a 01 Pathy and last week I did change the rear differential oil. I did use 80-90 valvoline synthetic why did I use 3.5 Qrts until the oil started to come out of the fill plug? Did I use too much? Why everybody said 1.5 or 3? Link to comment Share on other sites More sharing options...
