tmoore4512 Posted September 8, 2015 Share Posted September 8, 2015 That makes sense as well. Link to comment Share on other sites More sharing options...
Terranovation Posted September 8, 2015 Share Posted September 8, 2015 It's 12.65 volts with the engine running so the alternator is most likely the problem. It's getting worse, harder to start each time. I already have a spare one I need to get fixed up. Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted September 9, 2015 Share Posted September 9, 2015 Picked up a new 4wd switch from Nissan today. Got it installed, and now a have that nice green light. Probably a waste of 35 bucks... but I can't stand broken stuff. 1 Link to comment Share on other sites More sharing options...
tmoore4512 Posted September 9, 2015 Share Posted September 9, 2015 I tinkered with it yesterday but ended up getting nowhere due to havung so many other things that needed to be done around the house. Link to comment Share on other sites More sharing options...
k9sar Posted September 9, 2015 Share Posted September 9, 2015 let my 14 year old do some welding on it 1 Link to comment Share on other sites More sharing options...
tmoore4512 Posted September 9, 2015 Share Posted September 9, 2015 Awesome pictures. Way to get the kids involved! Link to comment Share on other sites More sharing options...
adamzan Posted September 11, 2015 Share Posted September 11, 2015 I see bondo Sent from my SGH-I747M using Tapatalk Link to comment Share on other sites More sharing options...
k9sar Posted September 11, 2015 Share Posted September 11, 2015 I see bondo Sent from my SGH-I747M using Tapatalk yea, the part by the bumper rotted completely off and all the stuff in my hiding-place fell out the bottom. Other spot was just eating through. Pop-rivet some window screen and a layer of bondo and she's good enough to pass inspection. Better sanding and a quick layer of paint to come later. Link to comment Share on other sites More sharing options...
adamzan Posted September 11, 2015 Share Posted September 11, 2015 Should have cut it out and welded in some metal since you have the welder. I have patched more than my fair share of holes with bondo, just not on this truck lol. Link to comment Share on other sites More sharing options...
tmoore4512 Posted September 11, 2015 Share Posted September 11, 2015 Inspection? They make you fix cancer before they pass you? Link to comment Share on other sites More sharing options...
01Pathmaker Posted September 13, 2015 Share Posted September 13, 2015 (edited) Left the 96 out of the garage for the night so mother nature can wash it. Edited September 13, 2015 by 01Pathmaker Link to comment Share on other sites More sharing options...
tmoore4512 Posted September 13, 2015 Share Posted September 13, 2015 Kinda started to sort out my no start issue... Link to comment Share on other sites More sharing options...
xterra Posted September 14, 2015 Share Posted September 14, 2015 Took it to get emissions tested. Passed without any issues. It was the first time in nearly 2 weeks that I've driven it. The wife had her OEM knee replaced with an upgraded aftermarket version and isn't cleared to drive yet, so I've been using her car since it gets better mileage. Link to comment Share on other sites More sharing options...
Kingman Posted September 14, 2015 Share Posted September 14, 2015 Lifetime warranty? Link to comment Share on other sites More sharing options...
teixeira Posted September 14, 2015 Share Posted September 14, 2015 (edited) :lol: Edited September 14, 2015 by teixeira Link to comment Share on other sites More sharing options...
xterra Posted September 14, 2015 Share Posted September 14, 2015 Lifetime warranty? Pretty damned close - they called it a 30 year knee... Link to comment Share on other sites More sharing options...
k9sar Posted September 14, 2015 Share Posted September 14, 2015 Inspection? They make you fix cancer before they pass you? only if it goes through to the interior from underneath... something silly like exhaust gasses filling the cabin Link to comment Share on other sites More sharing options...
CO_pathfinder Posted September 15, 2015 Share Posted September 15, 2015 Got meself a replacement injector cap (snagged the injector while I was at it). Got lucky to be honest because I showed up with just two screwdrivers, one phillips one flat, thinking that I would be in and out. Broke the phillips screwdriver trying to wedge a hood open (to be fair, it was a very big phillips, which is why I used it as a mini crow-bar in the past) The issue with this was that my flathead screwdriver was a very wide flathead. Which meant that it wouldn't fit any of the screws holding the caps in place.. But lo and behold, the very last truck I checked had ONE cap held down by flathead screws! Link to comment Share on other sites More sharing options...
Kingman Posted September 15, 2015 Share Posted September 15, 2015 (edited) Put an LED strip under the hood wired to the factory alarm switch on the core support. Worked, but seemed like it needed a smaller gap to fully open the circuit when the hood was closed as the light would flicker if I banged on the hood. Went to remove the switch to put a washer under it and proceeded to break it. Damn. Edited September 15, 2015 by Kingman 3 Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted September 15, 2015 Share Posted September 15, 2015 I finished soldering up my headlight upgrade harness, and installed it. Ended up with a lazy eye, relocated a ground and got both lights shining bright. Can't wait to see the difference tonight. Link to comment Share on other sites More sharing options...
CNAM Posted September 15, 2015 Share Posted September 15, 2015 Link to comment Share on other sites More sharing options...
Kingman Posted September 16, 2015 Share Posted September 16, 2015 Installed the Sway-a-Way torsion bars and Superlift UCAs that have been sitting in my garage for months. Need some low profile bump stops... rear is 17.5" from the ground to rocker, front is 17.25" Just washed it too. Link to comment Share on other sites More sharing options...
tmoore4512 Posted September 18, 2015 Share Posted September 18, 2015 Kingman...it looks good...You have a rock or something in the T case plate?Changed flippin starter AGAIN. Did not last 6 weeks... "Brand New" starter...pssssh.Duralast GOLD from Autozone...Exchanged it. Replaced it. Hell it starts now. Link to comment Share on other sites More sharing options...
stovanovich Posted September 18, 2015 Share Posted September 18, 2015 Sure it wasn't today but finished building, painting & fitting my completed winch bar 1 Link to comment Share on other sites More sharing options...
CO_pathfinder Posted September 18, 2015 Share Posted September 18, 2015 Nice stov. Its about time your rig got into the big leagues. Now for me to get off my ass and join you.. Link to comment Share on other sites More sharing options...
