RedRider3141
But all those bike tires! I assume it has some form of stability on it (training wheels) as a soft breeze would put K in the next county!
Heh, bike tires do add up when you start putting on the miles!
Today I looked at my pathy woefully as I pulled my motorcycle out of the garage.
Anyone want to guess what happens to an old starter when the points fuse closed and it goes unnoticed for about a half hour? Well, yesterday I replaced my starter.
You have exotic failures. :blink:
Finally put the proper size tires on. Got an extra lego wheel for a spare. I had to grind a little off of the spare tire holder lip so the hub cap would snap onto the wheel.
had the timing belt,water pump, alternator belt, fan belt, and two idler pullys replaced. to the tune of $800.00
should get me to 300 000 km. still need to address the thermo unit....and the rust.
WhiteOwl got an exhaust leak fixed today, the interior shoveled out and organized a little, fixed the droopy fabric on the cross bar in the headliner, changed the taillights out for the ones with the covers, moved the roof rack bars around to put a snow brush up there and washed him
he's a happy boy today
Hey it a nice looking rig Nunya
I installed my modified rack
I'm thinking about painting the 4x4 badges flat black and doing the 4x4 in white
Whoa! Why? That looks great with the body color match.
Maby match the 4x4 to body color and black out the background could look good :aok: basket fits nicely too
Do you get very much airflow back under the sunroof from your lights?
I opened mine on the freeway and everything was blown off the dash and you could really feel the airflow it followed the inner roof line to the windshieldand down to the dash,
Highway speeds with it open I get a good amount of airflow. My visors shake and I can feel it at my feet. Don't need no stinkin a/c!
Well I been a busy lil bee lately... more pix to come in my build thread for this truck...
Yesterday I was in shop to replace all oils.
Started assembling the hubs and brakes on the diamond front axle.
Almost time to hit the trail again!
Sent from my Desire HD using Tapatalk 2
Picked up a bunch of parts I was looking for. Pick and Pull finally had some pathfinders on the lot. Grabbed Drivers Side Torsion Bar Adjuster, Speedo Sensor (as I mangled mine getting it out), 4x4 & Low Range indicator switches. Then I really lucked out and found a 1990 SE on the lot. Pulled the rear disks out (shafts and all). They even had a 2006 X-terra on the lot, I was going to pull the seats out, but they weren't in very good shape. Been eyeing there inventory for the last several months and seldom come across anything worthwhile. 6 WD21s and and X today.
Looks like I'll be doing the disk brake conversion when I throw my axle back together :jig:
My buddy trogdor fixed my door lock on the drivers side, and replaced the brain for the factory alarm so I can have keyless entry...Just need to order a new clicker. Thanks Homie
Got my transmission fluid replaced yesterday.
handed over the keys to a dealership for them to try and diagnose the cooling system issues I have been having. :(
A chemical check just takes a few minutes hopefully the fluid doesnt turn green from exhaust gases
Well... changing my oil turned in to a hunt for an oil leak turned in to needing a new camshaft seal turned in to finding a water pump leak. :tired:
Looks like antother fun day tomorrow...
just realized that I have heated mirrors!!
