RedRider3141
1) New Wiper Blades
2) New Light Bulbs for the OEM Fogs
3) New A/C Belt
4) New P/S, Fan Etc Belt.
5) Filled all the nooks and crannies with my junk from my old car. (Emergency Supplies, Tools, Gloves Etc)
6) Flipped my 2" Drop Hitch from my old car to fit the Pathfinder.
The Belts weren't too bad. Anybody that can turn a wrench can do it, overall I think it was a 20 minute job (not including looking it up online).
found that 2 bolts in my manual hubs were missing, 2 fell out but were rattling around in the center cap, and the other 2 were still threaded in but not very much. got the 2 new bolts ad 4 new lock washers for 3 bucks and got er all fixed up.
and tightened the power steering belt.
Knocked the icicles off my front bumper...
I stared longingly at my pathfinder as I am still waiting on parts from America to fix mine. Now I am driving a Honda civic rental :suicide:
Kicked the tires to make sure the tires were still good, then put the tarp back over :)
  • Like 4
Serviced (repacked) the front wheel bearings, with some very valuable help from EmptyV.
Edited by fusion
same thing i did but execpt the tarp
is this for the r50s? every pathy?
Any Pathy with do :) Haven't driven mine in about 2 weeks. Stole my bros 4 cylinder ranger while he is out of town. Nothing like 28 mpgs!
Put the batteries on a trickle charge for the heck of it.
Re-aimed the washer nozzles
Cleaned headlights and taillights
Tomorrow:
New upper rad hose
lower tranny cooler hoses
coolant system flush
oem in cabin air filter
remove wiring for aftermaket temp gauge
I also need to verify my transmission fluid level, I kept getting readings of being way to full when checking it HOT, but Ill let the truck sit for a couple hours and see what it reads and drain it or leave it from there
Gonna be a cold sunday
My pathy is freezing to the driveway today.
**moved topic to garage, so everyone can play**
Im honestly suprised a thread like this didn't pop up sooner, generally I would call it an "all years" thread as they normally are for those stupid little annoyances that ain't really worth an update in a members rides thread...
Let's see... I removed the fender flares, the seat belts, and the ash tray. Today I'll pull the ECU, disconnect the fuel lines, remove the starter and break the engine bolts loose.
Today I remembered I have one sitting on 3 wheels in the garage.
Is one a cinder block or a milk crate?
Today (actually yesterday) I checked the O2 sensor using the ECM ( it's working!), than replaced the pass. side door hinge bushings, removed the K7N cone filter, my home made adapter and MAF sensor, made a stencil out of cardboard for a new adapter, made to rubber gaskets, than made a new adapter out of 1/2" plexi,
I stared at it from inside my nice warm house while it looks like an ice cube in my driveway.
I decided on a grill (ordering today) and started a parts list to get my front end in presentable order.
As of Tuesday my Pathy and I work for Direct TV.
If anyone knows of a ladder rack available for the WD21, let me know. I've got to buy or build one in 2 weeks.
I cursed mine for using so much gas :deadhorse:
Today I readjusted my Fan Drive belt because it squealed like crazy last night when cold! I guess I didn't get it quite tight enough yesterday.
picked up one of those Spectre MAF adapters today to mount my cone air filter, couldn't get the rubber grommet out so I cut it than found out the K&N would only go on a a certain amount and the hole was not covered, didn't have a plug to put in the hole so I used one of the Spectre air filters I found in the dumpster here ( a Honda owner thru a bunch of stuff away, 13 bulbs, 2 of those air filters, one red one blue),it sounds like the whistle is gone.
New alty, PS & AC belts. Whoo-hooo!
Today: Pulled the codes from the ECU (great write up btw, but I had to watch the video to fully understand what "flashing 3 times" really meant! :tongue: ) Only had code 55. Nice!
Now I'm working on adding relays for the headlights.
Replaced the sealed beams with new and changed the oil and air filter.
There was a small puddle of oil on the garage floor this morning, but I couldn't find anything leaking. :shrug:
I've got so much to do to the truck over the next couple weeks, I really don't need engine mysteries popping up.
