GoPathyGo
R50 SAS
HAHHA thats good brother!!!
Ok here is another teaser pic. Its up on wheels and driving around. Just needs some tweaking (as expected). Driveshaft is being done this Monday, Brake lines are also in the process of being lengthened, and THATS IT!!!
You should bring it up to ottawa for the wheeling trip we're planning!
I'm making Breaky, then I'll go out and do a sexy photo-shoot ;-)
Ok Here goes!!!
Heres how she sits.
Staang's Fab Inner "C" gusset/Coilover mount.
Staang's Fab 7/8" Steering/Trackbar
Staang's Fab W50 Crossmember welded AND bolted to beef up the Unibody
Staang's fab 3 link
Upper and Lower Coilover mounts
'98 Durango steering box for all the power to move the 35's
Plated, Plug welded, Sleeved steering box re-enforcement. Done on both sides of the Unibody (frame)
E-Fan, NO NOTICEABLE POWER GAIN. Tons of engine compartment space though.
I'll post pics of the double cardan joint Drive shaft. Should be ready on Wednesday. Also my brake lines will be longer as well!!!
The things that need tweaking:
Coil-overs, they're GARBAGE. Nuff said
I "should" get a sway bar :-)
Springs are a bit soft.Won't know for sure until I get the shocks to hold air.
Nice looking job. I'm soooooooo freaking jealous ! This might be my next step. If I bend another tie rod that might be my last straw any chance I could get those Staang fabed parts ?
Yep! Go to staangsfab.com or check 'em out on Facebook.
So jealous, really hope that they go and put a kit into production!
Hopefully this puts a fire under Tyler's ass ;-)
Very nice. Very nice indeed!
Jose
Id be interested to see a install thread of sorts for this kit
Got inspired by all these pictures
Step 1 completed:
Steps 2-500 left... :aok:
is there a specific reason for using the expensive coilover or could an axle be setup the same as jeep cherokee front axles with spring buckets and seperate shocks?
I think you would have a hard time getting coils to fit with the limited amount of room both on the truck and axle.
