R50 SAS
HAHHA thats good brother!!!
Ok here is another teaser pic. Its up on wheels and driving around. Just needs some tweaking (as expected). Driveshaft is being done this Monday, Brake lines are also in the process of being lengthened, and THATS IT!!!
Ok Here goes!!!
Heres how she sits.
Staang's Fab Inner "C" gusset/Coilover mount.
Staang's Fab 7/8" Steering/Trackbar
Staang's Fab W50 Crossmember welded AND bolted to beef up the Unibody
Staang's fab 3 link
Upper and Lower Coilover mounts
'98 Durango steering box for all the power to move the 35's
Plated, Plug welded, Sleeved steering box re-enforcement. Done on both sides of the Unibody (frame)
E-Fan, NO NOTICEABLE POWER GAIN. Tons of engine compartment space though.
I'll post pics of the double cardan joint Drive shaft. Should be ready on Wednesday. Also my brake lines will be longer as well!!!
The things that need tweaking:
Coil-overs, they're GARBAGE. Nuff said
I "should" get a sway bar :-)
Springs are a bit soft.Won't know for sure until I get the shocks to hold air.
  • 1 month later...
  • 11 months later...
  • 1 month later...
  • 2 months later...
  • 1 year later...
