slick250 Posted November 9, 2010 Share Posted November 9, 2010 Well, after lots of research and a lot of negative feedback on the subject, I am accepting the challenge of installing the VG30DETT twin turbo engine in my 1995 Pathfinder. I will try to take pics of the project and will be ordering the engine/trans tomorrow to begin my winter project. I mostly use this Pathy for running the sand dunes at Little Sahara State Park so I feel the twin turbo is a great way to build hill shooting power while still keeping it somewhat lightweight....plus I just love turbocharger noise the sand rails make on the dunes, so I hope mine sounds similar. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 9, 2010 Share Posted November 9, 2010 Hell the dunes is good a place as any for a turbo. slap some paddles on, them them tires fly and off you go! I wish you luck on your project and make sure you get pics of the fenderwall clearances and whatever custom manifolds you do up... Have you measured the DETT at its widest point and your engine bay at its narrowest point? Will you still have fenderwalls when your done? Or will you manifolds be peaking out from inside the wheel well? Link to comment Share on other sites More sharing options...
slick250 Posted November 9, 2010 Author Share Posted November 9, 2010 Hell the dunes is good a place as any for a turbo. slap some paddles on, them them tires fly and off you go! I wish you luck on your project and make sure you get pics of the fenderwall clearances and whatever custom manifolds you do up... Have you measured the DETT at its widest point and your engine bay at its narrowest point? Will you still have fenderwalls when your done? Or will you manifolds be peaking out from inside the wheel well? From my measurement so far, the wheelwells are the least of my worries..LOL Engine measurement almost same as frame rail width, and may require clearancing of frame...Steering shaft may be a bit of a problem. Link to comment Share on other sites More sharing options...
Slashjt Posted November 9, 2010 Share Posted November 9, 2010 pleeeeeeeeease take pics of everything!!! It's the same project I have in mind. Best of luck! Link to comment Share on other sites More sharing options...
edicer2 Posted November 9, 2010 Share Posted November 9, 2010 i dont think it will fit it barely fits in a z31 which has a larger engine bay Link to comment Share on other sites More sharing options...
slick250 Posted November 9, 2010 Author Share Posted November 9, 2010 i dont think it will fit it barely fits in a z31 which has a larger engine bay Yeah....I keep hearing that a lot. We will see. Only one way to find out! Link to comment Share on other sites More sharing options...
Kingman Posted November 9, 2010 Share Posted November 9, 2010 (edited) Ah. Someone stuck a VQ45DE in a 2-door WD chassis. THAT was interesting. You'll need to modify the firewall to gain clearance for the crossover pipe and what not, and definitely some other sheet metal and frame work to clear the DOHC heads. I plan on turbo-ing my Z31 MPFI swap in my '88 Pathfinder, the turbo will go right where the AC pump is. I had to cut a huge chunk of the firewall out just to fit the rear of the intake. Enjoy the wiring... Will you keep the factory intercoolers or run without? If so, where are you going to put them? The intercooler tubing? Will you be running the factory turbos? Is it an NA block that you'll be turbo-ing? An NA block makes a sheit load more power than a factory turbo block with less boost. What kind of clutch are you going to run? Are you going to run a 3" exhaust? Good luck with the build and take a lot of pictures. Edited November 9, 2010 by Kingman Link to comment Share on other sites More sharing options...
MY1PATH Posted November 9, 2010 Share Posted November 9, 2010 (edited) From my measurement so far, the wheelwells are the least of my worries..LOL Engine measurement almost same as frame rail width, and may require clearancing of frame...Steering shaft may be a bit of a problem. Hydro steer? put a ratio box on the firewall where the rag joint would be and the ram up under the frame where the CL would be. Expensive, but it is a solution... Ah. Someone stuck a VQ45DE in a 2-door WD chassis VQ and VK swaps are cool, those aluminum blocks both weigh about the same as the cast-iorn VG block Edited November 9, 2010 by MY1PATH Link to comment Share on other sites More sharing options...
veilside180sx Posted November 9, 2010 Share Posted November 9, 2010 I honestly don't see the point. It's hard enough to find room in the WD engine bay for one turbo...let alone two tiny T too small's. The DOHC in this application isn't necessarily going to help much, as the SOHC many times will flow better down low (where we need it) To each his own, and good luck with it. I'd settle for having room to stuff a single 50 trim in and call it a day w/o having to use a stupid oil pump to get it back in the pan. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 9, 2010 Share Posted November 9, 2010 are you kidding? VG30DE's make just as much power as a VG33E (oooh VG33DE's are fun) and almost as much power and VG30ET's The DOHC has a much more useable range of power in both turbo and NA versions. We just bash it because we don't have it and its too big to easliy retrofit... Link to comment Share on other sites More sharing options...
veilside180sx Posted November 9, 2010 Share Posted November 9, 2010 are you kidding? VG30DE's make just as much power as a VG33E (oooh VG33DE's are fun) and almost as much power and VG30ET's The DOHC has a much more useable range of power in both turbo and NA versions. We just bash it because we don't have it and its too big to easliy retrofit... I'm well aware of what you are saying. I see this in the KA as well. The SOHC due to the single large exhaust valve, flows better down low due to increased velocity than the DE. It's the difference between sucking through two straws vs one large. Obviously the higher up in the range you go, the DOHC will become more effective. Link to comment Share on other sites More sharing options...
MY1PATH Posted November 9, 2010 Share Posted November 9, 2010 I'm gonna have to dis-agree. yes each valve is smaller but if you add up the area of 2 smaller cirlces they can be less than half the size of a larger one and sill flow more. The thing is the DOHC (KA & VG) were nissans turning point into aiming for HIGER rpm power bands(they only went higer from there like the VQ35HR). To get some monster low end torqe out of a VG30DE all you have to do is advance the intake cam by 3-5 degrees and leave the exhaust cam stock. Link to comment Share on other sites More sharing options...
Specv1973 Posted November 9, 2010 Share Posted November 9, 2010 (edited) Good luck man, and good for you for having the balls to try something new. There will always be critics unfortunately. Edited November 9, 2010 by Specv1973 Link to comment Share on other sites More sharing options...
KovemaN Posted November 9, 2010 Share Posted November 9, 2010 I have seen the VH45 in a WD21 swap and I would strongly recommend against anything like it. You're looking at having to build new frame rails, relocate the firewall and swap out the entire harness and fuel pump. That is after you get all of the drivetrain stuff to mount up which is an adventure in itself. I would personally like to have the VG33ER. Shaping or cutting the hood is much easier than building a new frame. Link to comment Share on other sites More sharing options...
slick250 Posted November 10, 2010 Author Share Posted November 10, 2010 Just ordered the VG30DETT today. Engine,5 speed manual, wiring and ECU for $1800 shipped. Going to try to make this happen for about another 1000 to 1500 bucks plus my labor. Going to install a body lift and suspension lift also. It is mostly just to clear larger tires, but might help clearance issues on the swap also. Link to comment Share on other sites More sharing options...
veilside180sx Posted November 10, 2010 Share Posted November 10, 2010 I'm gonna have to dis-agree. yes each valve is smaller but if you add up the area of 2 smaller cirlces they can be less than half the size of a larger one and sill flow more. The thing is the DOHC (KA & VG) were nissans turning point into aiming for HIGER rpm power bands(they only went higer from there like the VQ35HR). To get some monster low end torqe out of a VG30DE all you have to do is advance the intake cam by 3-5 degrees and leave the exhaust cam stock. Thankfully, I have no issues with you disagreeing.=) I have yet to decide what I will eventually do to power mine. Link to comment Share on other sites More sharing options...
slick250 Posted November 10, 2010 Author Share Posted November 10, 2010 Four cam heads usually have a great power band, and lets not forget the VG30DETT engine has variable valve timing! Link to comment Share on other sites More sharing options...
sewebster Posted November 10, 2010 Share Posted November 10, 2010 How does VVT work on that engine? I mean, what is the mechanism to adjust the timing... extra cam lobes that only get used when engaged by something? Link to comment Share on other sites More sharing options...
MY1PATH Posted November 10, 2010 Share Posted November 10, 2010 not sure wich method nissan uses but there are several out there; tapered cam lobes; can be pused side to side by a solenoid so that a differant part of the cam is used in each rpm range. Hydraulic lock or magnetic lock cam gears; that hold the cam at differant degees depening on magnetic current or oil preassure. Varible lifters; increase lift when oil ps rises or event timing if a secondary lifter engages. there's more methods out there and I would also like to know which one nissan uses... Link to comment Share on other sites More sharing options...
veilside180sx Posted November 10, 2010 Share Posted November 10, 2010 (edited) not sure wich method nissan uses but there are several out there; tapered cam lobes; can be pused side to side by a solenoid so that a differant part of the cam is used in each rpm range. Hydraulic lock or magnetic lock cam gears; that hold the cam at differant degees depening on magnetic current or oil preassure. Varible lifters; increase lift when oil ps rises or event timing if a secondary lifter engages. there's more methods out there and I would also like to know which one nissan uses... The VTC (not VVL or VVT) on the VG30DETT and S14 SR only adjust the intake cam timing. The only motor in that genre/time frame that had true VVT or VVL (variable valve lift) as Nissan calls it, was the SR20VE/SR16VE. Edited November 10, 2010 by veilside180sx Link to comment Share on other sites More sharing options...
JamesRich Posted November 10, 2010 Share Posted November 10, 2010 Just ordered the VG30DETT today. Engine,5 speed manual, wiring and ECU for $1800 shipped. Going to try to make this happen for about another 1000 to 1500 bucks plus my labor. Going to install a body lift and suspension lift also. It is mostly just to clear larger tires, but might help clearance issues on the swap also. Awesome! I cant wait to see your progress, post lots of pics as you go. If someone can stuff a chevy V8 in a wd21 your swap should be possible. Have fun with the wiring though! James Link to comment Share on other sites More sharing options...
veilside180sx Posted November 10, 2010 Share Posted November 10, 2010 (edited) Awesome! I cant wait to see your progress, post lots of pics as you go. If someone can stuff a chevy V8 in a wd21 your swap should be possible. Have fun with the wiring though! James The SBC is actually more compact than the VG30DETT, therefore easier to stuff in there. Edited November 11, 2010 by veilside180sx Link to comment Share on other sites More sharing options...
Kingman Posted November 11, 2010 Share Posted November 11, 2010 Will you keep the factory intercoolers or run without? If so, where are you going to put them? The intercooler tubing? Will you be running the factory turbos? Is it an NA block that you'll be turbo-ing? An NA block makes a sheit load more power than a factory turbo block with less boost. What kind of clutch are you going to run? Are you going to run a 3" exhaust? Good luck with the build and take a lot of pictures. SBCs are no where near as wide as a DOHC motor like the VG30DE. Link to comment Share on other sites More sharing options...
shotzie417 Posted December 4, 2010 Share Posted December 4, 2010 hows that swap coming along got any pics yet ? Link to comment Share on other sites More sharing options...
slick250 Posted December 5, 2010 Author Share Posted December 5, 2010 hows that swap coming along got any pics yet ? Project is going slow but sure right now. Been real busy at work, but I have the engine and have been gathering a shopping list of parts needed yet for the project. The stock 3.0L is almost ready to be pulled from the vehicle, and I am getting ready to order the lift kit for the suspension. I need to figure out how to add pictures. Do I have to use an outside host for the pics? Link to comment Share on other sites More sharing options...
