lint Posted July 29, 2010 Share Posted July 29, 2010 So, I have some surface rust developing on my frame. I treated with rust-mort (kinda like POR 15) and I am wondering if I should paint (with tremclad) or undercoat it. If undercoating, should I use wax-based or bitumen-based? Thanks. Link to comment Share on other sites More sharing options...
nunya Posted July 29, 2010 Share Posted July 29, 2010 Brush on bedliner I don't like undercoat, always hear stories of it holdign moisture IN Link to comment Share on other sites More sharing options...
OldSlowReliable Posted July 30, 2010 Share Posted July 30, 2010 walmart spray on bedliner, lol. Link to comment Share on other sites More sharing options...
why3zx Posted July 30, 2010 Share Posted July 30, 2010 if you used anything even close to POR-15 chances are that frame will outlive you, i wouldnt worry about it, that stuff is like satan in a can. Link to comment Share on other sites More sharing options...
94 Pathy Posted July 30, 2010 Share Posted July 30, 2010 I wouldn't use undercoating on the frame. The POR-15 knock-off you used is wonderful. I'm using a cheap version of it from JcWhitney. I'll try & find my can of it & let you know exactly what it is called. I used it on my running bars, hitch, & gas tank. Planning on using it on the frame. Make sure you paint it on while it is humid. Yes, HUMID. It will dry harder & protect better. Good luck! Link to comment Share on other sites More sharing options...
nige Posted July 30, 2010 Share Posted July 30, 2010 i prefer using some sort of brush on rust paint. It gives you a faster indication of rust. The bedliner/rockguard/undercoating would be so thick it would hide the trouble spots, i would think. if you can get the metal clean, i think some self-etching epoxy primer would do a good job of protecting the metal. the paint is really just to protect the epoxy primer and make it look pretty. Use glossy texture paints; the dirt has a harder time sticking to it. Link to comment Share on other sites More sharing options...
lint Posted August 1, 2010 Author Share Posted August 1, 2010 Sorted! Wire brushed off the loose rust, and two treatments of Rust-Mort with a rinse after each, then a coat of Plastic-Kote's "Rust Not" in glossy black. Now, a good 20 hours later, my frame on the '95 Pathy is happy! I found a rust through the size of a quarter and will weld on a patch after the summer is over. I don't want to use an undercoating, because I want to keep an eye on the rust situation and not hide it from evaluation. Thanks for your advice folks, it helped....and this project is almost finished! Link to comment Share on other sites More sharing options...
Precise1 Posted August 1, 2010 Share Posted August 1, 2010 Nice!! Pictures might help the next guy... B Link to comment Share on other sites More sharing options...
GrimGreg Posted August 2, 2010 Share Posted August 2, 2010 Once you use the "paint over rust" type stuff, use regular paint to cover that, then undercoat. Each layer is there to protect the one under it. Link to comment Share on other sites More sharing options...
adamzan Posted August 2, 2010 Share Posted August 2, 2010 (edited) Why does it even matter the frame rusts from the inside out anyways. I just wash mine out frequently and give it a dusting of fluid film (thanks simon for telling me about that one) and the rot has been kept to a minimum in the past 3 years. I gave it a coat of rust paint 2 years ago and its still on there and the only rust spots are around the holes you stick the hose in. Edited August 2, 2010 by adamzan Link to comment Share on other sites More sharing options...
slade420 Posted August 2, 2010 Share Posted August 2, 2010 (edited) i found a can of tremclad rust paint (oil based) in my shed, it works really well. The can i found was tho was white rust paint.. so yes i now have a black truck with a white frame. Edited August 2, 2010 by slade420 Link to comment Share on other sites More sharing options...
