petespath Posted April 24, 2010 Share Posted April 24, 2010 Will this tire and rim combination fit at stock 2000 pathfiner. 15"x7" 6bolt chrome rims with 235/75/15 My current tire size is 255/65 R16 Will the new one clear the brakes and not rub the body. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted April 24, 2010 Share Posted April 24, 2010 IIRC, a 16" wheel is the minimum you can go with the late model R50 (99.5+) because of the larger brakes. However, this could be solved with the proper backspacing to clear the caliper. Hopefully someone else chimes in to confirm or deny that. Link to comment Share on other sites More sharing options...
DanAK Posted April 25, 2010 Share Posted April 25, 2010 I have a 2003 and I just test fit a few different 15" rims and they all fit with no problems. From what I have been reading I might get some rubbing when I change to new break pads but two minutes with a grinder should fix it. Link to comment Share on other sites More sharing options...
