88pathoffroad Posted April 22, 2007 Share Posted April 22, 2007 The 4-cyl transmissions are different and the TSB doesn't apply to them AFAIK. Link to comment Share on other sites More sharing options...
exploited789 Posted August 8, 2007 Share Posted August 8, 2007 i was worried about this my pathy makes a winding up sound in 1-3 gear but not 4-5 so instead of replacing the tranny i can just tilt the truck and pour in more oil???? is this true? Link to comment Share on other sites More sharing options...
94extreme Posted August 9, 2007 Share Posted August 9, 2007 try it or do it through the shifter Link to comment Share on other sites More sharing options...
exploited789 Posted August 10, 2007 Share Posted August 10, 2007 i went and bought some new gear oil today and im about to drain the trans and refill it but the thing is if this is such a problem why didnt nissan reconize it? im not trying to say im a nissan guru or anything because im obviously not im just wondering why the bulletin is from autozone and not nissan. i also have a hayes manual and it says the 1990 and on models take 3.6 and my truck a 1988 only takes 2.4liters im sort of worried about "over filling" my trans because i dont want to bust any sels or anything Link to comment Share on other sites More sharing options...
94extreme Posted August 10, 2007 Share Posted August 10, 2007 add more then 2.4L and read that bulletin again. the explentation to your question is in it. Link to comment Share on other sites More sharing options...
Simon Posted August 10, 2007 Share Posted August 10, 2007 Not ALL GL-5 fluids are harmful to our transmissions. There are some that don't contain the soft metal corrosive additives that can be used. You just have to be sure to research which fluids are not corrosive to soft (yellow) metals. Oh, and if you have a V6 engine, you definitely want 5.1qts in there. Link to comment Share on other sites More sharing options...
exploited789 Posted August 11, 2007 Share Posted August 11, 2007 my mistake it does say 3.6 in the manual. so if my trans is already making the whining noise will topping off my case to 5.1 make it stop or will i have to have it rebuilt still? Link to comment Share on other sites More sharing options...
Simon Posted August 11, 2007 Share Posted August 11, 2007 It might help. It might not. It depends on how far gone the bearing is. Try a quality synthetic lube, and some lucas oil stabilizer in there, at a ratio of no more than 20%. That should help quiet it down. Also, it should slow down any wear/problems in the tranny that are the source of your whine. Link to comment Share on other sites More sharing options...
94extreme Posted August 11, 2007 Share Posted August 11, 2007 what simon said. also, are you sure the tranny is whinning? not one of the diffs or the tc? Link to comment Share on other sites More sharing options...
exploited789 Posted August 11, 2007 Share Posted August 11, 2007 i think its the trans because it only makes the noise in 1st-3rd gear forth and fifth doesnt make the sound i dont know why it would be the transfer case cause the 4wd isnt engauged Link to comment Share on other sites More sharing options...
94extreme Posted August 13, 2007 Share Posted August 13, 2007 still could be the diff or tc. make sure your hubs do unlock indeed. Link to comment Share on other sites More sharing options...
exploited789 Posted August 13, 2007 Share Posted August 13, 2007 thank you for the alternative problems just the thought of having to rebuild my trans gives me nightmares. im pretty sure my hubs are unlocked i still have the stock automatic ones i put my truck in reverse and back up about 15 feet and no click so i assume they are unlocked. what should i look for if it would be the diff?" Link to comment Share on other sites More sharing options...
94extreme Posted August 13, 2007 Share Posted August 13, 2007 (edited) no click means there is an issue there.* * put it in 4xhi and drive forward some.. you should hear them click.. then back up 1m (3.3ft) and you should hear them click again.. that's unlocked for sure. Edited August 13, 2007 by mzxtreme Link to comment Share on other sites More sharing options...
exploited789 Posted August 13, 2007 Share Posted August 13, 2007 thank you i will do that. i just went and bought some redline mt90 at $9.99 a quart not too bad i suppose to what ive heard others paying for it plus they had it in stock so if anyone in southern CA needs some theres a place in hesperia called reeds automotive. Link to comment Share on other sites More sharing options...
exploited789 Posted August 14, 2007 Share Posted August 14, 2007 i checked it and it clicks like you said...agh the problems never end my pathy didnt pass smog now i have to buy a new cat too Link to comment Share on other sites More sharing options...
McClurgM Posted August 22, 2007 Share Posted August 22, 2007 (edited) I called Valvoline to ask about thier gear oils. the tech said that all valvoline gear oils although GL-5 are compatabile with soft metals. 1-800-team-val Edited August 22, 2007 by McClurgM Link to comment Share on other sites More sharing options...
jond8 Posted December 5, 2007 Share Posted December 5, 2007 Just fixed my trans with this same issue. Although it turned out to be the rear main bearing which was toasted I opted for a complete rebuild. It may be possible to fix this problem by removing the trans and just replacing the 15$ bearing. My 2 cents. Link to comment Share on other sites More sharing options...
bitemedoughboy.com Posted February 20, 2008 Share Posted February 20, 2008 (edited) why are you guys removing the shifter to fill the tranny??? its alot easier to remove the 4 bolts holding the shifter plate on... and you can pour it in as fast as it will come out of the bottle... Edited February 20, 2008 by bitemedoughboy.com 1 Link to comment Share on other sites More sharing options...
RowdoggNZ Posted May 12, 2008 Share Posted May 12, 2008 Hey. I have a 2.7 Turbo Diesel with the Manual 5 speed gearbox. The one in question i believe. I have a slight whine in 3rd gear only and its quite quiet. Do you think its the same problem and if so do you think its too late? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 12, 2008 Share Posted May 12, 2008 What year is your Terrano? They supposedly fixed this problem in 96. Link to comment Share on other sites More sharing options...
RowdoggNZ Posted May 13, 2008 Share Posted May 13, 2008 It's a 1991 so it will be the affected gearbox, so does it sound like the same problem? Think i should just load it up with MTF to increase the life of the gearbox? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 13, 2008 Share Posted May 13, 2008 If it's already whining, who knows. At least it stays in gear and doesn't pop out, eh? I'd add the extra lube just for insurance and see if it perhaps quiets down a little? Link to comment Share on other sites More sharing options...
RowdoggNZ Posted May 18, 2008 Share Posted May 18, 2008 Sweet will do, also I got recommended Castrol VMX by a local auto supplies shop, namedy Repco. Any Ideas? I wasn't sure if it was GL-5 Coz they didn't have any in stock. Where is the best place to get Redline in NZ? Link to comment Share on other sites More sharing options...
RowdoggNZ Posted May 28, 2008 Share Posted May 28, 2008 Sooooooo.. i got a diagnosis from an mechanic today, and the whine is this problem. Link to comment Share on other sites More sharing options...
4x4newbie Posted June 15, 2008 Share Posted June 15, 2008 wow. I'm glad if found this out. i just got my pathy and was wondering why it sounded like that. I am going to fill that sucker up immediately! Link to comment Share on other sites More sharing options...
