condor42 Posted January 12, 2010 Share Posted January 12, 2010 Hi everyone: Got a question related to chassis lubrication for my Nissan Pathfinder 1995 XE V6 4x4. Where are the points that need to be lubricated? Is only the bushings? the front drive shaft? And how can I be sure that the lubrication process was performed properly. Thanks a lot for all! You guys rock Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted January 13, 2010 Share Posted January 13, 2010 Hm.. upper and lower balljoints, tie rod ends, idler arm. That's all I know of at the moment that has zerk fittings if they're already installed. Front driveshaft, repacking your wheel bearings, lubing all door hinges. Think that's it. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted January 13, 2010 Share Posted January 13, 2010 x2 to all his... plus the tire carrier if you got one, but thats easy enough.. Link to comment Share on other sites More sharing options...
Precise1 Posted January 13, 2010 Share Posted January 13, 2010 Your universal joints should have zerk fittings, or at least a bolt in the threaded hole. Definitely buy some long fittings and install them so you can lube the U joints. B Link to comment Share on other sites More sharing options...
condor42 Posted January 13, 2010 Author Share Posted January 13, 2010 Hi guys: First let me thank you each one of you for all the valuable information concerning lubrication it def. help me a lot. I am learning a lot about my pathfinder thanks to all the posts, information as well as helpful and people with a lot of knowledge like you guys are. I will post a couple more questions that I have (hopefully you guys don't mind) and can give me your valuable feedback Thanks a lot and greeting from ultra-sunny Tucson-AZ Link to comment Share on other sites More sharing options...
