BoneZ Posted December 28, 2009 Share Posted December 28, 2009 So I am looking at doing a SAS on my 91 pathfinder I am only to the stage of starting to gather parts so it will be a while before I get to deep in the project. My pathfinder currently sits with a 3"SL and 3"BL to clear my 33" swampers almost measure 34". Well my main 2 questions are I want to fot 35" tires so I am thinking I will have to do a spring over axle swap to get the height, I want to know if others have done this to there pathfinder how did you get the back up to the same height to match. And also dose anyone have a picture of what they did for steering on a spring over axle dana 44 swap, The downer axle is a 89 waggy axle. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted December 28, 2009 Share Posted December 28, 2009 Some folks run 35s with a spring under setup and keep their body lift. Positioning the axle, spring hangers and shackles are key if you want to be able to clear 35s with minimal trimming. If you plan on keeping your body lift, I suggest you run a flatter spring if you go spring over. Otherwise you'll be sky high and you will have problem trying to match the height in the rear of the truck. When you go spring over, best thing to do is a cut and rotate your knuckles to maintain caster and pinion angle. Also, you'll need to run a high steer setup. You can get away with just running a high steer arm on the passenger side. No need to go full high steer unless you want the added benefit for clearance of your tie rod. This will minimize the bump steer you will see as the drag link is flatter. Link to comment Share on other sites More sharing options...
packie88 Posted December 28, 2009 Share Posted December 28, 2009 whats up bonez i did a spring under axle and am clearing 36s but i have trimmed my fenders a bit. try searching around. big good ole information is on nissannut.com. this question has been answered quite a bit Link to comment Share on other sites More sharing options...
BoneZ Posted December 28, 2009 Author Share Posted December 28, 2009 (edited) whats up bonez i did a spring under axle and am clearing 36s but i have trimmed my fenders a bit. try searching around. big good ole information is on nissannut.com. this question has been answered quite a bit Thats where i have been getting most of my information from packie88. athghout i found a sring over axle swap post http://nissannut.com/projects/SAS_WD21/and the http://nissannut.com/projects/SAS_3link/but im not sure about the hight with a leaf spring over to match. Do you have a build thread on your rig? Im just trying to be prepared as possible. Edited December 28, 2009 by BoneZ Link to comment Share on other sites More sharing options...
packie88 Posted December 28, 2009 Share Posted December 28, 2009 never made a build thread but if you have any questions ill be glad to answer Link to comment Share on other sites More sharing options...
BoneZ Posted December 28, 2009 Author Share Posted December 28, 2009 never made a build thread but if you have any questions ill be glad to answer What did you use to get the rear up to the height of the spring over axle front? Link to comment Share on other sites More sharing options...
yozsi Posted December 29, 2009 Share Posted December 29, 2009 (edited) What did you use to get the rear up to the height of the spring over axle front? I did custom 4 link in the rear and used 5.5 inch deavers. Edited December 29, 2009 by yozsi Link to comment Share on other sites More sharing options...
87pathy Posted December 29, 2009 Share Posted December 29, 2009 you can't put a d44 in a nissan Link to comment Share on other sites More sharing options...
packie88 Posted December 29, 2009 Share Posted December 29, 2009 87pathy u sure on that. and i used 5.5 inch lift coils for a bronco with a few coils cut out to get the rear up to height and did a long arm of the stock links Link to comment Share on other sites More sharing options...
87pathy Posted December 29, 2009 Share Posted December 29, 2009 87pathy u sure on that. and i used 5.5 inch lift coils for a bronco with a few coils cut out to get the rear up to height and did a long arm of the stock links possitive. Link to comment Share on other sites More sharing options...
packie88 Posted December 29, 2009 Share Posted December 29, 2009 explain cause im lost Link to comment Share on other sites More sharing options...
87pathy Posted December 29, 2009 Share Posted December 29, 2009 explain cause im lost is my sarcasm escaping you today? Link to comment Share on other sites More sharing options...
packie88 Posted December 29, 2009 Share Posted December 29, 2009 yea it is escaping me. im a little slow Link to comment Share on other sites More sharing options...
slade420 Posted December 29, 2009 Share Posted December 29, 2009 If you want to do it on a budget you could get coil spacers. Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted December 29, 2009 Share Posted December 29, 2009 or.... reweld your mounts higher/lower....or just save up enough until you can do it right the first time. Link to comment Share on other sites More sharing options...
DOA Posted December 29, 2009 Share Posted December 29, 2009 LOL....I think 87pathy is right. What you really want is a Dana 43 cause the 44 is just to big. Link to comment Share on other sites More sharing options...
87pathy Posted December 30, 2009 Share Posted December 30, 2009 you can get brand new coils for under 150 bucks. why spend 70 on spacers or an entire weekend of work to relocate stuff. check out James duff wildhorses 4x4.. i'ver an both. actually, i have a set i might sell for the right price 5.5" lift with winch. Link to comment Share on other sites More sharing options...
BoneZ Posted January 5, 2010 Author Share Posted January 5, 2010 87pathy u sure on that. and i used 5.5 inch lift coils for a bronco with a few coils cut out to get the rear up to height and did a long arm of the stock links Thank you for that info, and from my understanding if I leave it spring under axle it will be about the same a a 3" sl on a pathfinder. Link to comment Share on other sites More sharing options...
jim Posted April 2, 2010 Share Posted April 2, 2010 LOL....I think 87pathy is right. What you really want is a Dana 43 cause the 44 is just to big. you can use a d44 out of an early bronco it only 2in wider hub to hub. then if you pull the spindle off at the ball joint you can use spendles from a chevy d44 witch allows you to keep your six lug wheels. early bronco is left hand drive like nissan. Link to comment Share on other sites More sharing options...
87pathy Posted April 2, 2010 Share Posted April 2, 2010 you can use a d44 out of an early bronco it only 2in wider hub to hub. then if you pull the spindle off at the ball joint you can use spendles from a chevy d44 witch allows you to keep your six lug wheels. early bronco is left hand drive like nissan. the problem using teh EB D44's is that due to location of the center section, you WILL have oil pan issues. Full width D44 or waggy 44 does not interfere. Link to comment Share on other sites More sharing options...
itsme1738 Posted April 2, 2010 Share Posted April 2, 2010 go to ronin wheelers.com they have some sased pathys,like mine!but i am soa with 35s Link to comment Share on other sites More sharing options...
