goldeneye123454321
Fusible Link
Ok, I just figured out that i burned out one the fusible links onmy car. In particular the green one from the battery that seems to go the the ignition system. Does any one know what the specs for the green fusible link wire might be?
thanks
I belive its 14awg
I think I replaced mine with 12awg not sure if that was a good idea or not.
Why I usually yank the ones I find in J-yards to keep around. Haven't neede one yet, but hear enough stories on the boards to keep extras.
Not sure what size wire, but I replaced mine a long time ago with one from the dealer, it was only around $14usd.
Bah.....I hacked out the links, and hard wired them to a new + terminal. Much more secure, and no issues.
Until a short develops and melts your entire harness, rather than the 2" fusable link wire.
Anyone know what exactly gets power from the fusible link? I have several wires coming out and would like to know what they power if anyone here does . Thanks
Everything goes through the fusable links.my 93 SE has a total of 6. 3 brown, 1 green, and 2 black. One of the black ones is a short loop by itself. The black and the green ones are a unit and the 3 brown ones are a separate unit. They protect all the wiring harnesses from a catastrophic thermo event from happening. I don't recall where, but I had found a Nissan Z forum where someone had the specs for the various link wires and had converted to modern style links using maxi fuses I believe. I might go that route myself some day when I feel like messing with my wiring again.
