iLLlegal Posted February 20, 2009 Share Posted February 20, 2009 so I'm out here in my garage just about to get started on replacing my thermostat. well the first thing we need to do is to drain the radiator. so I go under the pathfinder and examine how to do this. you have to remove this so called "skidplate" to drain right?! WRONG! further examination of the skidplate shows that the previous jackass... sorry owner decided to remove the bolts that hold it on and WELD it into place looks like i wont be draining my radiator tonight!!! just beer now! sorry just a rant, havent had one of those in awhile Link to comment Share on other sites More sharing options...
unccpathfinder Posted February 20, 2009 Share Posted February 20, 2009 uhh...lower raditor hose...mine busted 3 times at the plug trying to drain it...so since then till now when i have brass on brass has been lower radiator hose Link to comment Share on other sites More sharing options...
GrimGreg Posted February 20, 2009 Share Posted February 20, 2009 Even if you use the actual drain, you should be able to reach it from the top, and there should be a hose that runs through a hole in the "skid plate". I just pop the hoses also, but with the skid in place that would make a hell of a mess. Link to comment Share on other sites More sharing options...
Precise1 Posted February 20, 2009 Share Posted February 20, 2009 LOL, welding has it's place. This is definitely not one of them... B Link to comment Share on other sites More sharing options...
94extreme Posted February 20, 2009 Share Posted February 20, 2009 yeah, you can do it from the top or bottom with the skid still on. the petcock is on the driver's side, iirc. i can check as my rad is out of the truck right now. Link to comment Share on other sites More sharing options...
RedPath88 Posted February 21, 2009 Share Posted February 21, 2009 Yep drivers side and it "should" have a rubber hose that points backwards and then 90's down through a hole in the skid plate/splash gaurd (because they are hardly skid plates ) as mentioned before. If you don't see if from below, look from the top, it may bethere just not sticking down through the hole If it's not there you can still let it drain onto the skid plate, just use a larger container to catch it.. that little dip in the bottom back of the skid plate is where most of it will drain from iirc Link to comment Share on other sites More sharing options...
GrimGreg Posted February 21, 2009 Share Posted February 21, 2009 that little dip in the bottom back of the skid plate is where most of it will drain from iirc Unless he welded that shut too..... Link to comment Share on other sites More sharing options...
RedPath88 Posted February 21, 2009 Share Posted February 21, 2009 This is true Link to comment Share on other sites More sharing options...
iLLlegal Posted February 21, 2009 Author Share Posted February 21, 2009 (edited) ah awesome guys! k ill check this out tonight. it looks rather hard to reach it from the top but i have long skinny arms that could probably pull it off. and nope that little dip is not welded so maybe this wil actually work. ill keep everyone updated . TY Edited February 21, 2009 by iLLlegal Link to comment Share on other sites More sharing options...
adamzan Posted February 23, 2009 Share Posted February 23, 2009 You could grind the welds off... Link to comment Share on other sites More sharing options...
