tekazgtr1984 Posted March 2, 2009 Share Posted March 2, 2009 Does anyone think it would be possible to fit 265x75x16 on 16x8 Ultra Rims on an 01 LE w/ no lift? Would 275/70/16 fit? Or would it be best to just stick to the 265/70/16's? I would say not possible but from what alexrex posted about his set-up it's definitely possible. I'm rolling on 32x10.5 (265/75R16) tires but I've got the AC lift coils. Check with Alex just to be sure but I bet it's possible. Link to comment Share on other sites More sharing options...
alexrex20 Posted March 2, 2009 Share Posted March 2, 2009 they fit on mine, but i don't think they'll clear the stock front bumper. also, 32s on stock wheels probably won't clear the struts unless you're using a super-skinny tire. Link to comment Share on other sites More sharing options...
larryt Posted March 10, 2009 Share Posted March 10, 2009 (edited) Year: '02 LE 4wd lift : OME HD coils x4, KYB GR-2 struts and shocks Wheels : 17" stock Tires : 245/70/17 (30.5") Firestone Destination AT Notes: No problems with alignment, no camber bolts needed, no rubbing, no "topping out" of the struts. 100% improvement in handling on/offroad over 95k mile old stock suspension. Photo: Edited March 10, 2009 by larryt Link to comment Share on other sites More sharing options...
Orangetang Posted March 16, 2009 Share Posted March 16, 2009 Winter Config: (Stock Rims) Year: 2002 Chilkoot Edition Lift: ~2" OME Lift, HD springs and 1" front aluminum spacers. Tires: 245/75R16 Firestone Winterforce UV Wheels: Factory 16" Nissan Alloys Notes: Absolute max tire size without going to a 4" BS rim. ~1/8" clearance between top of inside of tire and strut spring seat. Summer Config: Year: 2002 Chilkoot Edition Lift: ~2" OME Lift, HD springs and 1" front aluminum spacers. Tires: 265/75R16 Hercules Trail Digger MT Wheels: Pro Comp 16x8 4"BS Alloy Notes: Needed to remove front mud flaps because of rubbing. Largest tire possible without fender trimming. Link to comment Share on other sites More sharing options...
180sx Posted April 3, 2009 Share Posted April 3, 2009 Year: 1996 Pathfinder SElift : Stock/ no lift Wheels : Stock/ 15x8 Tires : BFG A/T 31x10.5 Notes: doesn't rub or anything. Update: just swapped my BFG for Goodyear AT/S tires. Same size: 31x10.50-15. Tires are not new, but I got all 4 for $120. I'd say they got a year left on them. I noticed that these, even though they are worn pretty good, have about 1/4" less clearance then my BFG's did. They still don't rub, so far, but it's something to note on, I guess. Also, when I measured my friends tires, they were all different. these are all new. He had a 33" that measured 31.5" some 35" that measured 34" and 33.5" a 38" that measured 36" and a 44" that measured 42" These are all different brands, by the way. When I talked to some tire shop guys, they all said that no tire comes the same size from different manufacturers. Weird... Link to comment Share on other sites More sharing options...
bandit22re Posted April 5, 2009 Share Posted April 5, 2009 i dont see many people with wheels like mine. whats the biggest tire i can fit on these? stock suspension no lift Link to comment Share on other sites More sharing options...
180sx Posted April 7, 2009 Share Posted April 7, 2009 well, considering stock is 235/75-R15 I would say stay around that size. I don't know the BS of that rim, or how wide it is (I assume 15x6) so I would say get a 245/75-R15. Link to comment Share on other sites More sharing options...
fleurys Posted April 17, 2009 Author Share Posted April 17, 2009 (edited) Year: 2001Lift: AC Coils , GR2 Struts, Rancho 9000xl shocksWheels: stock 16" OEM SE Offset +20Tires: Firestone Destination MT 265/75R16Notes: Eventhough the Tire WAS fitting under the strut, there was about 1/16th" of space. fearing that the tire was going to eventually hit the strut at highway speed (expansion), I decided to fit Wheels Spacers 1.25". Had to trim part of the lower front bumper and to recess part of the plastic inner fender. Total about an inch of trimming. Edited March 1, 2018 by fleurys 1 Link to comment Share on other sites More sharing options...
Pinip Posted April 17, 2009 Share Posted April 17, 2009 (edited) Year: 2001Lift: AC Coils , GR2 Struts, Rancho 9000xl shocks Wheels: stock 16" OEM SE Offset +20 Tires: Firestone Destination MT 265/75R16 Notes: Eventhough the Tire WAS fitting under the strut, there was about 1/16th" of space. fearing that the tire was going to eventually hit the strut at highway speed (expansion), I decided to fit Wheels Spacers 1.25". Had to trim part of the lower front bumper and to recess part of the plastic inner fender. Total about an inch of trimming. ...All cleeeeeeeeeeeaaaan and shiny... lots of mud waiting for you now... are you sure you want to get it scratched, mucky and banged all over ? ...so nice i'd drive to the Ritz Carlton with it... ...mine looks like it's been to Iraq or Afghanistan compare to yours... although i am not ashame of it... Edited April 17, 2009 by Pinip Link to comment Share on other sites More sharing options...
ben0326 Posted April 18, 2009 Share Posted April 18, 2009 (edited) Year: 2003 Chilkoot editionLift: none Wheels: Stock 16x7 and 16x8 Dick cepek dc-1, 4"BS and -12mm offset Tires: 265/70/r16 Bridestone Dueler revo Notes: No rubbing when the duelers were on the stock wheels. When duelers were on dc-1s, more clearence in strut, had to trim front fascia and melt plastic with heat gun to stop rubbing pic1 Would this same combination, 16x8 wheel with 4" BS and -12mm and 265/70/r16's work on a 1999.5 XE 4x4? edit- Actually the wheels I'm looking at are -11mm offset.. would the 1mm make that much of a difference? Edited April 18, 2009 by ben0326 Link to comment Share on other sites More sharing options...
180sx Posted April 20, 2009 Share Posted April 20, 2009 That tie size is stock my friend, so yes it ewould work. Link to comment Share on other sites More sharing options...
ben0326 Posted April 20, 2009 Share Posted April 20, 2009 That tie size is stock my friend, so yes it ewould work. Thank you Link to comment Share on other sites More sharing options...
LovemyPathfinder Posted May 7, 2009 Share Posted May 7, 2009 (edited) Ok so i am running 245 75 16 on my pathfinder and there is no rub except for in reverse with the wheel the whole way to the left. stock bigger tires nicer cushionier ride too! Edited May 7, 2009 by pathfinder9035 Link to comment Share on other sites More sharing options...
01silvapathy Posted May 7, 2009 Share Posted May 7, 2009 You still havent fixed that light??? lol Link to comment Share on other sites More sharing options...
LovemyPathfinder Posted May 8, 2009 Share Posted May 8, 2009 ^^^ those are old pics. this is what i had on for awhile until the fuse melted?? wierd it was. so i took it off and i am planning to properly run it this summer on a light bar. I used zip ties...lol!! Link to comment Share on other sites More sharing options...
180sx Posted May 11, 2009 Share Posted May 11, 2009 does anybody think 15x10 wheels with 3" BS would work? Or would that just be way too wide? I havne't seen anyone with wider than 8" wheels, so yea... Link to comment Share on other sites More sharing options...
lcstay10 Posted May 20, 2009 Share Posted May 20, 2009 hey, i have a 2002 pathy se 4x4. pretty much stock. iv started to do some off roading with a couple of friends who have jeeps. they give me @!*% about driving a pathy, but i still hang with em. i don't have the funds for a lift or anything, but i want some new rubber so i can smoke em. iv been doing my reasurch, and it looks like the BFG A/T tires look perfect for me. but, will they fit on my stock rims? i have the 16 inch 6 spoke and what size should i look for that will fit my truck. i still want to drive highway and around town/parking lots with it so i wanna make sure it fits. im not quite sure how to post photos on NPORA yet, but i have a pic here. http://www.pinkbike.com/photo/2212835/ please let me know, all help is appreciated. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted May 20, 2009 Share Posted May 20, 2009 BFG must make A/T tires in the same dimensions as your R50s stock meats. Don't quote me on that, though... Link to comment Share on other sites More sharing options...
lcstay10 Posted May 20, 2009 Share Posted May 20, 2009 ya, i went on to tire rack.com, and i entered my car type, and they didnt come up. some other A/T tires did, but iv heared great things about the BFG Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted May 20, 2009 Share Posted May 20, 2009 ya, i went on to tire rack.com, and i entered my car type, and they didnt come up. some other A/T tires did, but iv heared great things about the BFG I'm surprised BFG doesn't have anything. If you're willing to check out other brands, Toyo's worth a look for sure. I've got the Open Country A/Ts on my '98 and they are absolutely wonderful. Link to comment Share on other sites More sharing options...
GoPathyGo Posted May 20, 2009 Share Posted May 20, 2009 ya, i went on to tire rack.com, and i entered my car type, and they didnt come up. some other A/T tires did, but iv heared great things about the BFG Tirerack.com is kinda weird with trucks. For some reason, it basically only really shows stock sizes or factory option sizes. For cars, they'll show you more options. I don't know the measurements of your wheel, but I'm sure non-stock tire sizes will fit. So, for example, if yours came with 255/65/16, 245/70/16 will fit. I made those numbers up, but you get the idea. So long as you stay approximately within the overall diameter of your stock tire + wheel and don't get something much wider than the factory tires, you should be fine. You can calculate overall diameter in inches, you can use the following formula: ((Tire width/25.4)*(Aspect ratio aka the 2nd number on your tire in the 255/65/16 formula/100))/2 + Rim diameter. I would bet something BFG/Goodyear would fit your stock wheels. Next time your Jeep friends laugh, congratulate them on their brilliant foresight. Having 2 Jeeps means they can use one for spare parts when stuff begins falling off the other "car". They can also get bulk discounts when parts begin falling off both "cars". I hear Staples gives 10% off cartons of paper clips and glue... Link to comment Share on other sites More sharing options...
fleurys Posted May 20, 2009 Author Share Posted May 20, 2009 Hey guys, even though I know everyone is helping...Let's try to keep this thread for the intended purpose. Which is to have pictures and details of the setup members have done with their suspension/tires combo.... If not , well, this thread will become like the others....a bit of info and a lot of chit chat... Hope you're not taking this the wrong way... S. Link to comment Share on other sites More sharing options...
GoPathyGo Posted May 20, 2009 Share Posted May 20, 2009 (edited) Hey guys, even though I know everyone is helping...Let's try to keep this thread for the intended purpose. Which is to have pictures and details of the setup members have done with their suspension/tires combo.... If not , well, this thread will become like the others....a bit of info and a lot of chit chat... Hope you're not taking this the wrong way... S. I wouldn't call Tyler and my reply "chitchat". He's just a new guy asking a simple, quick question because he may not know the thread structure (though I agree it's kinda weird since it says he's been a member since July but has only 2 posts) and we're throwing suggestions out there. I'd rather give a suggestion and THEN point him to the right thread than say,"Hey schmuck, you're in the wrong section." Dunno about all the light zip tie stuff. That said, I now have KYB front struts, which actually aligned easier than the Ranchos. Weird... Ride is better too. So, now I'm at Year: 2003 LE Springs: AC 2" Front: KYB GR-2 Rear: Bilsteins Tires: 235/85-16 Wrangler MT/R with Kevlar, which have ridiculously aggressive treads. Not swampers but much higher and knobbier than the BFG A/Ts I had. 1 camber bolt each side. Used to rub till I trimmed bumper about 1/4" and cut front fenders in half. No rubbing now. Edited May 20, 2009 by GoPathyGo Link to comment Share on other sites More sharing options...
lcstay10 Posted May 21, 2009 Share Posted May 21, 2009 yup, sorry i got it off track. and ya, lol i made a membership when i first got my pathfinder, but i have had zero money after buying a car and a downhill mtb. but now i have some income flowing, and wanna make the pathy a little better. the nissan runs like a champ. i love it. thanks for your help. Link to comment Share on other sites More sharing options...
Fukinitupagain Posted May 21, 2009 Share Posted May 21, 2009 does anybody think 15x10 wheels with 3" BS would work? Or would that just be way too wide? I havne't seen anyone with wider than 8" wheels, so yea... Yeah you can do that but you will have to do some trimming of the fender & part of the front bumper (especially at stock height) but unless you have like a 12.50 wide tires then you wouldn't want to go with that wide of a rim. I've seen a 32x11.50 tire on a 15x10 rim but I wouldn't recommend it (just because the tire shop says it can be done doesn't mean that it should be done). Link to comment Share on other sites More sharing options...
