Slartibartfast Posted November 19, 2015 Share Posted November 19, 2015 Question's been beat to death, but the quick version: two ways to find out. One, floor it on gravel, if it makes two ruts you have LSD, one wheel peel, no LSD. Two, put it in park or gear with the engine off, chock the front wheels, jack up both rear wheels, spin one. If the other rear wheel spins the other way, no LSD. If you can't turn the wheel by hand without putting the trans in neutral, LSD. The LSD rear axles also came with an orange sticker on the back. Link to comment Share on other sites More sharing options...
Slimshade1 Posted November 19, 2015 Share Posted November 19, 2015 Question's been beat to death, but the quick version: two ways to find out. One, floor it on gravel, if it makes two ruts you have LSD, one wheel peel, no LSD. Two, put it in park or gear with the engine off, chock the front wheels, jack up both rear wheels, spin one. If the other rear wheel spins the other way, no LSD. If you can't turn the wheel by hand without putting the trans in neutral, LSD. The LSD rear axles also came with an orange sticker on the back. Okay will try it im not sure about a orange sticker all I saw on the axle was yellow paint ill check for the sticker when I go to lunch at work Link to comment Share on other sites More sharing options...
Slimshade1 Posted November 21, 2015 Share Posted November 21, 2015 I got no sticker Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
