mitsu Posted August 14, 2009 Share Posted August 14, 2009 If it has a little sticker it probably has it, run the vin number to see original equipment, do a burnout on some gravel and see if you have 1(open) or 2(LSD) ruts. there is a orange sticker at the top of the diff Link to comment Share on other sites More sharing options...
MTXaudioSYSTM Posted April 1, 2010 Share Posted April 1, 2010 i have the pretty little sticker LSD =] Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 8, 2010 Share Posted June 8, 2010 Interesting. Anyone here ever welded up their front diff? Using manual hubs of course... Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 8, 2010 Share Posted June 8, 2010 I guess I should explain... Being used to full size axles, and using different methods of traction gaining devices from high dollar (ARB, Detroit) to low end (Welding up the spiders!) I had to ask... I know that the CV axles probably could not handle the excess force that would be exerted, but that is fixed by using the breakable warn hub internals...designed to fail before the axle does... Just looking at different IFS options... Link to comment Share on other sites More sharing options...
dhardison Posted June 8, 2010 Share Posted June 8, 2010 It's amazing, of the Pathys I've looked at including my own the lsd sticker is more durable than some of the frames! Link to comment Share on other sites More sharing options...
kiwinoz Posted September 8, 2011 Share Posted September 8, 2011 Look at the bright side.......LOCKER Hey there TerranoNZ. Lokka for the rear diff. Could you piont me in the right direction where to get one of these, please. I have a Z24 petrol Pathfinder, open diff, H233b as far as i can tell. Don't know if it 2 or 4 spider gears, or 27/31/33 spline. I have heard it'd the same as the front of a Partol, but don't know what model/year. Do you know what model lokka fits, or of anyone who has one fitted? I've been searching all over, and not had a straight answer. Thanks mate LS Link to comment Share on other sites More sharing options...
Methfinder Posted November 17, 2011 Share Posted November 17, 2011 I was thinking of doing a straight axle swap to get my rear lsd. There is an infiniti Qx4 sitting in a junkyard about 5 min from my house. i've been taking stuff off of it like roof racks and struts (well at least part of the struts). The Qx4 is like the LE Pathfinder, if i'm not mistaken. Correct me if I'm wrong here. Verify if I'm right. Doesn't the infiniti Qx4 have LSD in the rear? My Pathy is a 1999.5 and the Qx4 is almost beyond recognition. (probably 2000, 2001)I'm pretty sure It has the same body style as mine. Link to comment Share on other sites More sharing options...
AzZo Posted June 25, 2012 Share Posted June 25, 2012 well i own a 1995 xe and believe it or not i jacked up rear end and spun wheel they both turned so thats a big yes I have a limited slip differential,Then the crappy 2 ton floor jack I was useing bent under the weight. I know two tons is 2000lbs and the pathy is at least 3500lbs. but all i had at the time and i had to know.no harm no foul and i know better than to be underneath a vehicle with out jack stands. 1 Link to comment Share on other sites More sharing options...
Towncivilian Posted June 25, 2012 Share Posted June 25, 2012 One ton is 2,000 lbs. Your floor jack must have been lousy or defective. Do you not have an orange "LSD" sticker on the diff cover? Link to comment Share on other sites More sharing options...
Kyle94 Posted June 25, 2012 Share Posted June 25, 2012 just because both wheels turned... does not neccesarily mean it has lsd... one of my other trucks (have had three) both wheels turned. but it did not have lsd. and the other, one tire spun and the other did not. Link to comment Share on other sites More sharing options...
kagedkitten Posted March 16, 2013 Share Posted March 16, 2013 Hey, if you have the lsd sticker, but its dry, could that just be the problem? I dont hear anything. We did jack it up, and it the other wheel spun in the opposite direction. But i swear that i have felt it at times. i have tried looking up this but i wasnt able to find anything thanks so much for the help! Link to comment Share on other sites More sharing options...
Trogdor636 Posted March 16, 2013 Share Posted March 16, 2013 By dry do you mean no gear oil? If so, I'd crack open the fill hole on the back and check. The fluid should be level with the hole. Link to comment Share on other sites More sharing options...
kagedkitten Posted March 16, 2013 Share Posted March 16, 2013 Ya. The whole area is dry outside of it, so thats why i am assuming that. I will try and crack it, but i have read how hard they are so i am not sure if i can but i will try!! If it is dry, could that make it not work?? Im trying to be positive that it works and just needs fluid, but i have read as well, that if it does need fluid, it usually makes noise when it is low/dry. Link to comment Share on other sites More sharing options...
Towncivilian Posted March 17, 2013 Share Posted March 17, 2013 (edited) Anything will make noise with low or no lube. If you don't know the last time the diff fluid was changed, just change it. Many fluids already have LS additive in them already. If you live near Advance Auto Parts, you can get Mobil 1 75W-90 for cheap if you order online using discount codes (Google for them). Edited March 17, 2013 by Towncivilian Link to comment Share on other sites More sharing options...
kagedkitten Posted March 17, 2013 Share Posted March 17, 2013 Excellent!! I will give it a shot. Thanks so much Link to comment Share on other sites More sharing options...
Trogdor636 Posted March 17, 2013 Share Posted March 17, 2013 Most people use a 1/2 ratchet/breaker bar, but the proper tool is a 13mm square drive socket. If you have a Harbor Frieght nearby you can pick this set up.... http://www.harborfreight.com/12-piece-drain-plug-socket-set-94961.html I'm not saying you need to spend the money, but if you think it may round out the drain plug you should pick that up Link to comment Share on other sites More sharing options...
kagedkitten Posted March 17, 2013 Share Posted March 17, 2013 Thank you!!!!!! i would have been very upset if i did that!!!! It would be my luck too Link to comment Share on other sites More sharing options...
enkrypt3d Posted March 20, 2013 Share Posted March 20, 2013 http://www.amazon.com/Royal-Purple-Performance-Synthetic-Automotive/dp/B0007QGT34/ref=cm_cr_pr_product_top Would I need 3 quarts of this for my LSD? Thx Link to comment Share on other sites More sharing options...
Towncivilian Posted March 20, 2013 Share Posted March 20, 2013 That's fine. Link to comment Share on other sites More sharing options...
enkrypt3d Posted March 20, 2013 Share Posted March 20, 2013 How much do I need for my 95? 3 quarts? Link to comment Share on other sites More sharing options...
Towncivilian Posted March 20, 2013 Share Posted March 20, 2013 Just under 3 quarts. Link to comment Share on other sites More sharing options...
SkiBumBrian Posted February 13, 2014 Share Posted February 13, 2014 Just watched a vid on youtube where a guy used his e brake to help his LSD grab traction..... interesting! Link to comment Share on other sites More sharing options...
Dma251 Posted October 29, 2014 Share Posted October 29, 2014 Just watched a vid on youtube where a guy used his e brake to help his LSD grab traction..... interesting! They call those "Cutting Brakes", I believe. I've heard it works well. Link to comment Share on other sites More sharing options...
DECALMAN Posted March 31, 2015 Share Posted March 31, 2015 I got lucky with my recent purchase! Link to comment Share on other sites More sharing options...
Slimshade1 Posted November 18, 2015 Share Posted November 18, 2015 so if i spin the wheels what way should they go or how else could i find out if i have lsd Link to comment Share on other sites More sharing options...
