Fuel saving tips
Vertigo
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
Cold air kit will make you consume more fuel, not less.
Chip won't really help fuel economy either, unless you really want to be running premium all the time.
Keep it tuned up, keep the injectors clean, change the O2 sensor at regular intervals, make sure the tires are properly inflated, keep it at or below 60mph on the highway, use cruise control when possible, use smooth throttle inputs, don't hammer the throttle everywhere.
I get 19.2mpg average per tank - 90 SE V6 *automatic*.
Depends always how frugal you want to be. Two options here:
option one:
Drive smoothly, steady, easy, keep 'er tuned and well maintained
keep tires up to the recommended pressure
keep the speed down as much as you can stand
use A/C as little as possible and don't drive with the window open on the highway.
option two:
shed weight and help out aerodynamics as much as possible:
remove roof rack and spoiler (if equipped)
remove rear spare tire and carrier
get rid of any junk on board
slightly over inflate the tires
leave all extra passengers on the side of the road
get some free running hubs
use smallest possible tires
let me just say, if you bother going for option two, then maybe you should reconsider owning a thirsty SUV
hmm I dont think airpressure has a major effect (i think mythbusters busted that one) but low air pressure can increase the contact patch and give a higher coef of friction but I dont think it would be significant...but I could be wrong...and I think the same goes for the roof rack and spoiler...they don't increase your frontal area all that much so I don't see removing them saving anything more than maybe .1mpg if that
but yea keep up with the and fix any exhaust leaks for sure...
I just got a new job where I have to commute a an hour each way and I cant part with my pathfinder
I was driving 700 miles a week B4 I moved to CA and that was at $2.50 a gallon and was paying about $100 a week in fuel...take that in a month and thats enough to keep the pathfinder and go buy an older accord that gets 28ish mpg and keep the pathy for offroading and what not... just run out the cost of fuel vs keeping the pathy and getting a commuter car... you'll see that the fuel is eating your budget quickly
Edited by unccpathfinder
more surface area contact doesn't = a rise in the coefficient of friction (the coefficient stays the same. the CoF of rubber on asphalt is 0.5-0.8).
the amount of force that friction exerts is equal to the coefficient of friction times the weight of the truck. the amount of surface area in contact has nothing to do with it.
Like others have said, just drive it easy, keep it in tune, and get RID OF THE JUNK IN THE TRUNK!
Although, today i got my best mileage in a month, with a computer, monitor, a stereo system, 3 people in the pathy and the a/c on the whole time :blink::huh:
I always get the best mileage when I'm not staring down at the fuel gauge :shrug:
Any got some good fuel saving advice? more so tune up or perfomance tips to help. Does a chip help or does anyone know were to get a cold air kit for a 94 pathy.
-vertigo
Here's a hard one, I picked up about 2 mpg after I had my Doug Thorleys installed... well actually the first week It went down cause I kept gettin heavy on the gass trying to test 'em out but after learing restraint my higway mpg went up to about 20 (17ish before headders)
check your o2 sensof and your Mass AirFlow sensor too. I think theres a MAF cleaning writeup in the how too section here if its dirty that could hurt your mpg too
Just maintain the thing...
but the thorleys to help.
I've got the ceramic thorleys with a K&N drop in air filter, 4.88's pushing 35's... I get ATLEAST 18MPG on the way to TDS i got 21 B)
the fuel pump in a dodge caravan is easily accessable from the drivers side midway back. If you pull the hose with the yellow clip, run a tube from that port into your tank and jumper 12 v into the connector, it'll drain the caravan into your pathy.
not that I have ever done such a thing. ;)
edit... if you use the green clip connection, that's the return line and you'll have to attach your hose to the fuel line rather than the fuel pump
Edited by k9sar
ok your right on my terminology but yes contact patch does have a lot with the force of friction being resulted into the system...This is why dragsters have wide tires and not some regular street tire on the back of them...If the same compoound/dia were used for a dragster but one was half the width of the other and everything else in the system remains constant the one with half the contact patch will slip more...it's also a function of the rubber compound (a stiffer rubber will provide a lesser resultant force than a soft "sticky" tire
A tire to the road is much different than a block to sandpaper or a book on a slope as typical statics's problems portray them...so yea my terminology was fuzzy but the concept is true...we talked a lot in RVD (road vehicle dynamics) of how rubbers and adhesives do not typically follow standard equations of friction (which is not 100% true its a matter of finding the equivalent coef of friction for the specific tire and applying it to the equation)
but any how tire pressure is insignificant to loosing MPG's
What about getting summer tires (smaller treads) instead of all terrains? And lighter rims?
I'm thinking of getting a set of smaller, lighter tires and lightweight rims for my rig. I can change it to the all terrains and my stock rims when I start wheeling :)
Also, yes, any exhaust manifold leaks you have, fix them... mine is leaking and it's cost me about 2 mpg... :(
i always keep my tires inflated around 40psi they tires are rated to hold more but its like riding a bike whats easier low air or keeping them hard?
Think of it this way your getting what 15-18mpg but how much are you saving cause the pathy is so reliable? If you had a crappy american car you'd be spending more to get it fixed so it all balances out in the end. Now a lil jap car to commute......
Scott
I checked it again last night and even paying for insurance on both pathy's and on my 07 camry and driving 80 miles a day...I'm saving enough in fuel/oil costs on not driving my pathy to pay for my car and insurance on it...as gas goes up that margin grows even larger...
If you're not making more than I'd say $65k you better get a commuter b/c its going to cost you more on gas then what your are making to make the drive...that or drive to the town you work in and get a hotel room for 4 nights and then drive home on fridays after work b/c I bet that would be cheaper than the gas as well...
If you max out the pathy for mpg's you're still only going to get maybe 23 or 24 but I seriously doubt it
no chit? i guess if different rubbers don't typically follow the standard equations of friction, then i don't really know what i'm talking about. lol.
and i'm just going off of what my physics professor said. he also brought up the question "why do dragsters have wide tires?" he told us it was because since the tire is bigger and has more air in it, it's harder to heat up. and since energy is lost as heat, it would be a good thing to have a big tire that's hard to heat up.
but i could be mistaken. i can't remember 100% of what my professor said because i was spacing out at the time.
I would love to have your professor...mine just talked about how to derive the equations, not even the uses of them :crossedwires:
yea...I was talking about it with an "engineer" i work with he's got his BS in physics and he started digging on all these physics/engineering sites and all kinds of philosophy's came up about the different realm's of friction there are and how to in theory take a completely frictionless material and put it in a vacuum to make them become "bonded" together so that the friction is infinitely large
It gets into dynamics instead of statics and all crazy with tires...I like you had a hard time paying attention in school but I recall discussing that the leading edge of a tire of its contact patch is considered "static" where the rubber elastically stretches to provide rolling resistance or some crap
heres a link to the google search that will give you tons of different philosophies on it...http://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUS247&q=friction+of+tires&btnG=Google+Search
sorry to thread jack...but yea I think we both agree that tire pressure in this application isn't going to gain fuel mileage :deadhorse:
actually, in my last post i said that less air pressure = less air in the tire = more heat = more energy loss. so by that reasoning *which was the theory suggested to me by my physics professor-i don't know how it works in the real world* less tire pressure means less fuel economy. but i'm no expert.
well all that different friction theory sounds way too complicated for me anyway. lol.
for sure...along with all other "engineering/physics" in the real world...they teach you these BS equations that aren't true in real scenario's and you go to get the real world calcs and you have to make the right assumptions to have a valid analysis and then you have to convince someone else it's true...they've got me doing loads reports and stress analysis' here at work and I hate it b/c I suck at making assumptions and I'm either super conservative or I make one wrong assumption so I can do the calc and it's not applicable according to the boss
whoops...I missed that one...ohh well
yeah, the only way to get real information is to do a field test, mythbusters-style.
and to actually contribute to this thread:
try to coast for a while before completely stopping. say you come up to a stop light and you're about 100 yards away. just let off the gas and roll to a stop. best-case scenario is by the time u get to the limit line, the light will have changed to green and you still have some momentum so that you don't have to start from a stand-still.
