gixxaben Posted April 13, 2008 Share Posted April 13, 2008 hows it goin guys and girls am in the middle of removing the transmission as the thrust/throw out bearing is makin a whole lot of noise now iv got all trans separated from the block but it still in place cos of the input shaft and now the transfer case is now fouling the torsion bars mount problem is, did i have to take off the mount that holds the torsion bars and transfer case off aswel ive taken off the gearbo mount and thought it would be enough but theres no more room to slide the whole unit out doe to the torsion/transfer case mount in the frickn way any tips would be greatly appreicated cheers Ben Link to comment Share on other sites More sharing options...
trogdor Posted April 13, 2008 Share Posted April 13, 2008 Ya the torsion bar mounts do need to come off to get the tranny out, to make it real easy take out the front diff as well and all the cross members, and you should have no problems. Link to comment Share on other sites More sharing options...
