geoff Posted July 1, 2004 Share Posted July 1, 2004 Can anyone help me? My pathy wont start. When I turn the key I get all the power to the windows, doors, radio, etc. But it wont start. Just a couple of clicks than nothing. I took the battery and had it tested. Its good. I think it might be the starter but I got it started once after it quit working and than it wouldnt start again. So would that still be the starter? And if so how do I change that out? Any suggestions? BTW it is a 93 Pathy SE. Link to comment Share on other sites More sharing options...
Simon Posted July 1, 2004 Share Posted July 1, 2004 First thing to do, as has been mentioned here many times, is check all your connections. A loose ground wire, either on the battery, or the vehicle could cause it to do this. If it is the starter, it's not hard to replace, just sometimes a PITA to get out of it's location, but it's do-able. I've never done it on mine, so I'm not sure on the specifics, but I'm sure someone could shed some light. Good luck Link to comment Share on other sites More sharing options...
Mr. Pickles Posted July 1, 2004 Share Posted July 1, 2004 Search is your friend. Starter replacement Link to comment Share on other sites More sharing options...
geoff Posted July 3, 2004 Author Share Posted July 3, 2004 Thanks guys. I saw the starter replacement guide right after I posted. Sorry. But my question was do you think it could be that? I had already checked all the connections everything was good. I have heard starters go bad before and it sounded different than on other cars. Thats why I was wondering. But Pathys are a diff kind of vehicle so who knows. I am attempting to replace it tomorrow. I dont know much about cars so wish me luck. Thanks for the help. Link to comment Share on other sites More sharing options...
somethingcool Posted July 3, 2004 Share Posted July 3, 2004 When it won't start, try banging on the starter with a wrench or hammer, if it starts after that then you need a new starter. Link to comment Share on other sites More sharing options...
ToddtheRobot Posted July 4, 2004 Share Posted July 4, 2004 that happened to me a few years back, and actually turned out to be the starter relay. so also check that. i learned that the hard way. put in a new starter, and it was still broken. turns out, i could have spent 5 bucks instead if 155. Link to comment Share on other sites More sharing options...
