88pathoffroad
Rear Spring Options For Lifting Your WD21 Pathy
page 1
Yep, it was this info you posted that I was thinking of. I'm pretty sure it was in a different thread at first (or different place in this one). :shrug:
part num code dia tag color
52001117 FH - .500 (grey)
52088102 FJ - .520 (green)
52088103 FK - .530 (yellowish. old part number 52001119)
52088181 FL - .540
52088361 FM - .550 (blue)
52088362 FN - .560 (yellow) [definately yellow, just got a pair]
52088104 GK
52088105 GL
52088363 GN - .600
52089141 GP
52089171 DL
Exactly......no need for spacers if you get new UCA's. Most aftermarket ones are made to allow for more natural angles of the ball joint, same as if you added a spacer to your current UCA's
What about aftermarket UCAs and the spacers? The would lift more with a t-bar tweak right?
Aftermarket arms don't actually create more lift range, they (all but one) just correct the angles of the ball joint once lifted.
So has anyone had any luck just buying new springs for a JGC and installing them with a successful 3-4" lift?
Ok I'm trying to lift my pathfinder and I'm ganna use the jeep springs and reindex my t bars do I need to get different shocks and do I need to do anything with the sway bar links.
When I did mine, the rear adjustable shocks no longer were happy. I never really used the SPORT/COMFORT settings anyway. I would suggest new shocks that add a few inches of travel compared to stock. I put Monroe shocks on my old 95 but I have seen other people using Rancho shocks
