coaz4x4 Posted September 25, 2007 Share Posted September 25, 2007 Here's what I gather from the Haynes manual I got (since I don't have the owners manual)... '88 Pathfinder Nissan Specs: 3-5/8 qt engine oil (10w-30) 11 quarts coolant (6 coolant, 5 water) 7-5/8 pint trans (API GL-4 ??) 2-3/8 qt xfer case (API GL-5??) each diff: 2.75-3.125 pint (API GL-5??) DOT 3 Brake Fluid I plan on replacing all of these fluids since I just got it used, and have no idea when they were last changed/serviced. Any suggestions/advice on fluid types or brands? Two specific questions: 1) how do I dispose of coolant?? 2) Does the brand of spark plugs and wire make alltogether that much of a difference? (ie. Bosch vs. VatoZone store brand) Thanks! Link to comment Share on other sites More sharing options...
94extreme Posted September 25, 2007 Share Posted September 25, 2007 please search around.. there is a whole thread on plugs.. another related to manual tranny.. gl5 is a nono on 5speed. i have the same fluids in all TC and the diffs; mainly for ease of it. coolant: recycle. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 26, 2007 Share Posted September 26, 2007 NGK plugs work fine, so do Bosch Platinums from what I hear. Plug wires don't really make much difference. Make sure you have a ratchet, extensions and a u-joint before going after the #6 plug. Or use the spark plug removal tool that should be under the rear seat if it's still in there. If you have the manual transmission, up the dosage of gear oil to 5.1 liters instead of 3.6 liters like the book says. The fill hole was located too low on the case on the 5-speeds from 87-96, so it needs more fluid for proper lubrication of the internal trans parts. One way to give it more is to jack up one side to tip the vehicle far enough to allow addition of more fluid, or you can remove the gear shifter and pour it in from the top if you feel adventurous. Link to comment Share on other sites More sharing options...
exploited789 Posted September 26, 2007 Share Posted September 26, 2007 so it IS possible to just jack one side up? i thought i saw some one on here say they tried it and it came out of a weep hole or something of the sort (i thought only water pumps had weeps holes?) Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 27, 2007 Share Posted September 27, 2007 Sure it is. The only other hole in the tranny is the vent tube that goes all the way up the firewall under the hood. You can park a Pathy pretty far over and it won't leak. Link to comment Share on other sites More sharing options...
