pvpathy Posted April 22, 2007 Share Posted April 22, 2007 (edited) My mother in law is taking over our pathy so we can get a pickup. The drivers side alarm switch doesnt work....so if you unlock the truck from there when the alarm is set,it will go off. Its ok if you open pass door or gate first.Also the keyless entry never has worked,it acts like it accepted the codes but still doesnt work. I would like to disable the alarm completely and obviously it doesnt matter about the keyless entry. Is there a relay or fuse I can pull,or a switch thats easy to get at I can make permanently open or closed so it never activates the alarm? Thanks! Edited April 22, 2007 by pvpathy Link to comment Share on other sites More sharing options...
pvpathy Posted April 22, 2007 Author Share Posted April 22, 2007 I found a fuse to kill the horn,but the ignition disable still works any ideas? TIA Steve Link to comment Share on other sites More sharing options...
vengeful Posted April 23, 2007 Share Posted April 23, 2007 Pull the security relay? Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 23, 2007 Share Posted April 23, 2007 Why don't you replace the door switch? They don't cost that much. It's a simple on-off switch. Link to comment Share on other sites More sharing options...
pvpathy Posted April 23, 2007 Author Share Posted April 23, 2007 Why don't you replace the door switch? They don't cost that much. It's a simple on-off switch. I suppose I probably could,but I dont really want to put another $100 into it as I'm already losing about $4500 on it already. She has no use for the alarm anyways,half the time the keys are in it anyways.I'll try pullin the relay. Thanks guys! Steve Link to comment Share on other sites More sharing options...
Iceman2989 Posted August 19, 2012 Share Posted August 19, 2012 I pulled the relay cause I was having the same problems. Worked like a charm! Link to comment Share on other sites More sharing options...
