UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
94 Pathfinder speakers
Grumpy
The four larger speakers sound like crap in my daughter's Pathfinder. I went to Crutchfield to find out what size they are, and Crutchfield says they don't sell speakers to fit this vehicle. That's a first for me. Before I go out and plunk down some dough on the wrong speakers, what sizes do I need?
One web site reports one set of 5 X 7s and one set of 4 x6s
Also, will the front door speaker panels pop off with just a panel tool?
Yep. I have a set of the carbon-fiber Infinity speakers from a Pathy SE in my Chevy van, they sound GREAT. :D They're 5x7's. The door panel comes off pretty easy, but the clip around the inside doorhandle is a PITA...it snaps on around the handle, just gotta prise it off carefully with a wide screwdriver or appropriate prying tool.
Guest finding_a_path
I just did my fronts today. I actually stuffed 6x8s in the factory location. It took about 2 hours to install them though! I had to mutilate the factory plastic bracket P... I say stick to the 5x7 or 4x6 to make life simpler. My speakers were 2 7/16" deep, and clear the window barely. That is with the factory bracket cut out in the back.
For mine, driver side wire colors were: Yel/Black(-), Green(+).
Pass side: black(-), black/white(+)
Definitely use a panel puller to get the panels off. The panels are made of a week fiber board, so it will break easily. Instructions for the door panel removal are: 1) Unscrew the plastic lock knob.
2) remove small plastic cap in armrest.
3) Remove #3 screw in armrest.
4) Slide armrest towards rear of car... lift and remove.
5) Remove 2 more #3 screws holding panel on.
6) Pop door handle trim off.
7) Use panel puller to remove clips (10 or so)
8) Lift the panel out of the window sill.
hope that helps!
:type:
At $200 for any of them, I'd get the Infinitys, both because I'm partial to Infinity stuff [have some of their speakers and love 'em], and because if you decide on 5x7s front and back, you can get another set for $100 instead of another $200. =)
  • 16 years later...
What do you guys do with the small column speakers on the front driver and passenger side when replacing the door speakers? My small speakers both seem basically dead, but they don't show up on crutchfield.
bump from the grave, 16 years. daaaamn.  okay.
Depending on what has happened with the audio system in your truck, the tweeters may not work.  The factory stereo did not have an amp. The amp was separate, and had a built in cross over for the tweeters.  If that amp was bypassed for an aftermarket stereo install, the tweeters wont work.
Hey thanks for the reply! Turned out the amp wasn't bypassed when new head unit was installed and that was the issue: amp was garbage.
I bypassed the amp and now one of the tweeters is great! other is blown. Going to get a set of component speakers and replace the column and door speakers up front :)
