5523Pathfinder Posted February 27, 2007 Share Posted February 27, 2007 Ok everybody, thought I would drop some knowledge on a issue I have been fighting on my pathfinder. It first started with a long crank and not starting for a few seconds, then turned key off, then on, then fired up. Then it was ok for a few days, then it got cold. I noticed on cold mornings this same thing would happen. A few days later I was driving down the street and I lost all power for about 3 seconds, then everything was fine. WTF, right! Anyways, I finally get it to do it at work and I check for codes, none set. So then its on to fuel and spark. I can hear the fuel pump buzzing. I check pressure and with the key on, it goes up to aobut 35 PSI, then drops to zero. Umm, thats not right, pressure should hold. So I remove my fuel pump and sending unit and I find small particles blocking the pickup. Tried to clean it, but to no evale, it didnt help. I replaced the pump and sending unit (The pump was getting noisey and my gas gauge was all over the place). Got it all running again and was fine for a few days. But then, it happened again. Here I go again. Now I find really weak spark. I swap the coil and transistor and its still hard to start or wont start at times. I knew my cap, rotor, plug wires, and spark plugs were all good. I remove the cap and rotor, then remove the cover for the crank sensor. What do I find? I find my distributor eating itself! Yes, the shaft bearing was coming loose and spreading aluminum shavings all over! Great, get a new distributor, install and great for a few days, then the hard starts happen again. At this point, as a professional technician, I want to shoot myself. I have absolutly no idea what could be causing this problem, but wiring came to mind. I checked and double checked every inch of my engine harness all the way to the ecu. I even thought to take the ECU out and put it in the freezer to duplicate a cold day. Nope, nothing. So, all of this has been happening over the course of almost a month. My biggest problem is that the problem is so intermittent. About a week ago, I was on my way to work, driving on I-5 and everthing enginewise, just shut off. I am coasting over to the shoulder dodging other cars and just as I get there, everthing comes back on. Ok, this is just wierd. I get to work and I try and think of any possible reason for all of this. I remembered about 6 months after I got Big Homie, he wouldnt start one night after work. I pulled it in and for the fuel pump not coming on. I found the fuel pump relay was cracked and broken on its backside. I replaced the relay and everything was good. Even replaced the cover for those relays being that it was missing. I go back to those relays and think "Everthing shutting off, then coming back on. Yeah, it could be a relay". So I notice the EGI relay right next to my shiney fuel pump relay. I pull it out and find a hairline crack in it on the side. I test it, and it works. Now, I dont like it when I find things like this, so I get a new relay. Wouldnt you know it, I havent had a problem since. I tore the relay apart and find a small amount of rust inside. I take the relay, shove it in the freezer, pull it out about a hour later, and sure as @!*%e, it dont work. I went back through the nissan manual, and I couldnt find anywhere about how that relay would effect things like that. I will say this, my truck has never run smoother and been more reliable. I imagine many will read this, and chances of it happening to someone else? Who knows! But I thought I would share. Or maybe you should go get a new relay and throw it in your rig. Link to comment Share on other sites More sharing options...
RedPath88 Posted February 27, 2007 Share Posted February 27, 2007 Issues like that drive me nuts... but that is good info and thanks for sharing! *Makes mental note to check relays Link to comment Share on other sites More sharing options...
bertrenolds Posted December 27, 2019 Share Posted December 27, 2019 Dude this may be the answer to the problem I have been chasing forever. I thought it was the fuel pump relay but that never fixed it. When I had the no start crank for ever issue it's cold out I pull my fuel pump fuse and it starts and dies then i fut the fuse back in and have to give it gas but it starts barely. I'm checking my egi relay tomorrow. Link to comment Share on other sites More sharing options...
Mr_Reverse Posted December 28, 2019 Share Posted December 28, 2019 I hate the intermittent issues. It makes the diagnosis so much harder. The Titans had a recall for the relay that powered the ecm a while back for similar issues. Link to comment Share on other sites More sharing options...
