Guest vinces red 90 Posted November 12, 2006 Share Posted November 12, 2006 have a 90 finder and can anybody tell me how the alarm on the concoul works.i don't know if i should have a keypad key if so i don't i just have regular door keys. its a rocker type switch that say on/impact any ideas. thanks vince Link to comment Share on other sites More sharing options...
unccpathfinder Posted November 12, 2006 Share Posted November 12, 2006 if its like the 1 in a 95 u need to have a key switch...i think if ure fast enough u can unlock the doors and get in and get the key in the ignition b4 it will go off...i just turned mine off cuze it was annoying... Link to comment Share on other sites More sharing options...
Guest vinces red 90 Posted November 12, 2006 Share Posted November 12, 2006 thankyou!!! Link to comment Share on other sites More sharing options...
SC88Pathy Posted November 12, 2006 Share Posted November 12, 2006 On my 88 I to enable the alarm I have to turn the alarm switch to on or impact off while the engine is running. The pathy then has to run for (as far as I can tell) at least five minutes. If not then the alarm won't arm. When I get back in I usually have enough time to set my laptop bag down on the passenger seat and start the pathy before the alarm goes off. Also if I turn the switch to on while the pathy is off, the next time I drive somewhere the alarm will activate once I turn the engine off. Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 13, 2006 Share Posted November 13, 2006 I'm not sure when they went to the remote-controlled alarm on the factory setup. Can anyone with a 90, 91 or 92 confirm having a remote? Link to comment Share on other sites More sharing options...
govols74n Posted November 13, 2006 Share Posted November 13, 2006 just disconnect the dinosaur, it's not like some one is out to steal an old pathy, and even if they are, the old alarm is garbage. (IMHO) Link to comment Share on other sites More sharing options...
94extreme Posted November 13, 2006 Share Posted November 13, 2006 On my 88 I to enable the alarm I have to turn the alarm switch to on or impact off while the engine is running. The pathy then has to run for (as far as I can tell) at least five minutes. If not then the alarm won't arm. When I get back in I usually have enough time to set my laptop bag down on the passenger seat and start the pathy before the alarm goes off.Also if I turn the switch to on while the pathy is off, the next time I drive somewhere the alarm will activate once I turn the engine off. that doesn't sound right at all. mine works like it supposed to.. i do have some keyfobs (94) but i just use the key.. you have like 15-20sec before it goes off when you get in. Link to comment Share on other sites More sharing options...
