fastskier
Everything posted by fastskier
yup did that earlier this year. as I say - I 've had enough problems with locks - I really hope I am done.
Tried running the chains on the rear tires a couple times. It was much better - no banging and I could go when it was so deep that I was pushing snow with my bumper. However with my chains (heavy duty V style), there was some interference issues that caused me not to be able to go over 15km/hr otherwise I thought I was going to rip something off due to the metal on metal sound. And yes my chains were very tight as they have the three cams on the side plus I use heavy duty bungees. At first I noticed that they were chewing into my fender flare on both sides in the wheel well. I carved the interefering part off with a knife (you can't tell that I did anything) and tried it again. The next time I couldn't figure out what it was hitting on but I think it was the rear sway bar mount. Suffice to say I don't think my chains are meant for my pathfinder. They are still great though for emergencies when you get to the top of the road and ski all day to find 2 feet of new snow on your truck at the end of the day. Going 10 km/hr is way better than getting stuck on some desolate logging road in the middle of winter.
After taking it to the shop they determined nothing was wrong with it. I drove it for awhile and it just seemed like the ECU needed to adjust to what the engine required. This took some time. Lately I've been noticing that if I take the battery cable off the battery (which resets the ecu) my pathfinder will have a lag when accelerating from stop for awhile. It seems like it needs time for the ECU to adjust to what the engine actually needs.
Door light on when door is closed - '94 Pathfinder
fastskier replied to fastskier's topic in The Garage
Finally figured this out due to another post - turns out it is the rear latch for the rear hatch. I tried moving mine forwards (towards the windshield) but that didn't work. I then spaced it up with some 1/4 flat washers (plated) and it works like a charm. No more strobe lights at night from under my dash!! This site rocks! -
As posted in other threads, the fix to this problem is usually to resolder some of the connections on the door lock control module board. Else you can change out the board for $200 at the dealer. The board is located behind the side panel in the back. Just above the rear wheel well. There are two boards there - on mine one was silver and bigger (not the one you are looking for) and the other was grey and smaller (lower and closer to the front). Confirm that it is the right one by unplugging the connector to it. When I did that all my doors locked. Anyways I took mine out last night and sure enough there were 2 pins that were missing solder. Soldered them up and reinstalled. At first I couldn't get it to lock, they would lock and then go right back up. Drove it around a bit and the locks seemed fine but then I parked and the same thing happened for about four cycles. It now seems to be working fine - hopefully it just had to reinitialize itself or something. Hopefully that's the end of the problem.
Rear Drivers Side Window Doesn't Work
fastskier replied to fastskier's topic in 90-95 WD21 Pathfinders
thanks guys - I pulled the master switch out and didn't even do anything and it started working again. Until it breaks again I'm not fixing it. -
hmmm, I would say water pump (mine went and exhibited exact same issues) but since it was changed 30K ago... Maybe a bad seal was used?
After searching though the forum I couldn’t find anything that directly related so here goes: 94 Pathfinder SE My drivers side rear window doesn’t move. Both the drivers switch and the door switch don’t work. Window lock button is definitely not engaged since I can move all of my other windows. There are no sounds emitted or anything when the switch is held down My first plan of attack was to pull the door panel and check for power at the motor when the switch is depressed. Any other suggestions?
This is a minor issue but it’s a pain in the @ss. Basically my truck always thinks that one of my doors is open. I have checked the two front door switches and they seem fine. Before I go tearing apart my truck looking for the short has anyone come across this before?
hmmm, interesting. I have never heard of ABS being put on only the rear. It sure doesn't work that well that I can tell. But then maybe I don't miss what I can't feel. too bad it wasn't all the way around. Thanks.
I have a 94 Pathfinder SE (I think) - it has the lego wheels with 31's stock. The other day I was noticing that the ABS light came on when I started it and then turned off after a little bit. Basically like it should. My question is - does my pathy have ABS? It sure doesn't feel like it when I'm locked up sliding down the road with my studs trying to dig into something. Is there something wrong with my abs? I tried searching but I couldn't really find anything on this. Thanks, Paul
turns out that my LSD does work - just not when its really slippery (ice). I tried it in some dirt/sand and both tires were digging down...
update: no engine check light has come on. I started to notice a black fluid being blown out of the tail pipe when I started the engine. Kind of oil/water mixture. I then checked the oil late last night and thought I noticed gas in it. Changed the oil and had to start it up again to move it forwards to get the garage door closed. Checked the oil again and still thought I noticed gas in it. At this point I am scared to drive it and I think its either a blown injector or a dropped ring. Any other suggestions?
I did a search on this and got a few threads that seemed like they covered some of the issues but I wanted to see if anyone out there had any other ideas. 94 4x4 SE Pathy. 216K km's. Problem: Today I first noticed a lack of power. Didn't think too much of it at first. ThenI noticed the idle getting really low when warm and loping between 200-500 rpm. Watching the tail pipe while it was idling and stepping on the gas I could see black smoke coming out (I could smell the unburnt gas too). Engine stalled a couple of times @ idle. Also would stutter below 1500 when I stepped on it but once above that it would run fine (lack of power though) Truck history: tune up 2 years ago (40K km's). new plugs, fuel filter, egr valve. Brand new air filter. Cleaned the MAF last month. I have not changed the o2 sensor. I have tried the mode III diagnostic but it says every thing is fine (55). Any ideas?? Thanks, Paul
so no one who has removed their O2 sensor can tell how they did it? I plan to take a torch to the exhaust when its cold, heat up the pipe and try to get the O2 sensor off quick. Opinions?
how are you guys removing your O2 sensors? Mine (94) has never been removed that I know of and is rusted in pretty well. I tried putting a wrench on it and smacking it with a hammer but I am afraid of breaking something. I let some liquid wrench soak in it overnight so I will try that but any tips would be appreciated.
Cleaned my MAF sensor tonight on my 94. Pretty easy. Its basically bolted right on to the back of the air cleaner box. Its a thin black rectangular box bolted to an aluminum manifold. Two screws (phillips) to get it off - the bottom one is a little tight to get to. And like 88 says be carefull taking it out - pretty fragile. Thanks for the info on the O2 sensor, I'll tackle that next.
Cool - I have to do this. I've looked for my oxygen sensor though and I haven't been able to find it - it should be screwed into the exhaust manifold with wires coming out if it ?? I also too would like a refresher of where my MAF is - I thought they were on the downstream side of the air filter?? Thanks
no one else has any ideas on why chains on the front might be harmful to the transfer case/driveline? I did some searching on the net and all I came up with is the oversteer problems. I'll have to check but I believe the manual says to put ONLY 2 chains and only on the rear.
oh trust me - 4wd was engaged when I got stuck. When you get stuck going up a hill the easiest thing to do is back down but when there's tons of snow you have to give a fair amount of power to get things moving. That's when the hubs go bang because they have to engage again because you are changing direction. You must not have been stuck before I take it?
Does anyone know the exact reason for chaining up the rear only? I read a Ford 2003 F150 4X4 manual and it said if only putting on 2 chains to put them on the rear tires. I assumed that was because of the problem of the rear end wanting to pass the front end when going down hill (been in a truck doing that - its an exciting ride down when you constantly have to gas it to keep it straight). Perhaps though these directions were due to issues with the drive train. Anyone have more insight on this?
Ya I would say that its rear wheels only for sure - what about 4 wheels - that can't be too bad can it? I can see why guys put different front hubs on though - that engaging and disengaging is fine while you are going in one direction but once you get stuck or have to turn around they suck!!
pretty sure my front passenger wasn't spinning. With those chains on it is pretty hard to spin the wheels as they are very aggressive.
I was out on the weekend in deep snow and I have some questions for you guys. Here's what happened: 12" of fresh snow My Pathfinder has 215K km's on it with older 31" tires (read - not great in snow). We couldn't go any further so I put some new chains on that I bought on the front. The chains are a heavy duty Vbar style. I got them pretty tight as they have cams to get them tighter than normal. Once I tried to go I found that I was spinning the rear wheels like mad and the fronts were just bearly turning. I also noticed that when I turned the wheels a certain amount the chains would start to contact the fender I believe - there's not that much clearance! I also had to turn around and in doing so when I would put it in reverse sometimes I would get a loud bang when I started to move (like the hubs were engaging under load). I thought the hubs stayed engaged untill it is taken out of 4wd? Based on this experience I am definitely going to put the chains on the rear wheels next time. This is not what my friends do with their pickups because then your steering is not great but since it seemed like it put so much load on my Pathfinder I'm not doing that again. So - Is something wrong with my transfer case? Why were my front tires not turning as fast as my rears?
I looked at the rear axle & there isn't an orange sticker - rather there's a white one (or what's left of one). I did notice that there was oil coming from the plug but not enough to leak on my driveway. I'll try jacking it up and seeing if the other side spins or not to make sure that I have a LSD. Thanks for the reply.
