16
Everything posted by Cuong Nguyen
Cuong Nguyen replied to RedRider3141's topic in The Garage
Trying to figure out wing design.. not liking this version... Sent from my SAMSUNG-SM-N920A using Tapatalk -
Definitely take some pictures Sent from my SAMSUNG-SM-N920A using Tapatalk
I cannot rmember when the design changed. They went from a full sheet to holes stamped into them. If you can get the supercharged tc thst be great but understandable if you cannot. Sent from my SAMSUNG-SM-N920A using Tapatalk
You need a 96+ tc and matching flex plate for it to work. Sent from my SAMSUNG-SM-N920A using Tapatalk
The flex plates are different but will bolt up. There was a post somewhere of those differences but I have not been able to find if you saw in the last post. You wont need the sensor you speak of. Sent from my SAMSUNG-SM-N920A using Tapatalk
Forgot i was welding thin sheetmetal after switching from 1/4 in. Oops. Sent from my SAMSUNG-SM-N920A using Tapatalk -
I know of only one person that has done it and Mr. Reverse may recall of it. For it to work, they utilized the Trailmaster lift it to drop the front and aftermarket control arms to clear the coilover and custom towers. Sent from my SAMSUNG-SM-N920A using Tapatalk
PPE all the way! Bought a full face shield and it saved my face. Grinder blade chipped and hit thr face shield hard. No penetration but left a nice dent in the plastic. Sent from my SAMSUNG-SM-N920A using Tapatalk
Shelly Sent from my SAMSUNG-SM-N920A using Tapatalk
Hope all is well with you bud! Sent from my SAMSUNG-SM-N920A using Tapatalk
Making a winch bumper. Sent from my SAMSUNG-SM-N920A using Tapatalk -
'87 P/F vg30i to vg33e engine swap
Cuong Nguyen replied to zchase1's topic in New People Start Here!
Wishing you luck Sent from my SAMSUNG-SM-N920A using Tapatalk -
Bumper brackets Sent from my SAMSUNG-SM-N920A using Tapatalk -
I used gasket sealant to fill in the gaps. Now the gap is larger lol. Ebay has the window moulding for hardbodies which work Sent from my SAMSUNG-SM-N920A using Tapatalk
I still suspect timer Sent from my SAMSUNG-SM-N920A using Tapatalk
Damm that's bad Sent from my SAMSUNG-SM-N920A using Tapatalk -
1993 Pathfinder inner fender and core support replacement
Cuong Nguyen replied to Jmoor85's topic in How-To's
I highly advise you get OE Parts unless you want to settle for cheap thin chinese body replacement parts. Go to a junkyard and cut out what you need. I bought a cordless grinder. I had to go through what you are going through. Im using a cheap chinese core support and it is flimsy. The only thing keeping it from flexing further is the original middle support. Salvage as much as you can from thr original parts. Sent from my SAMSUNG-SM-N920A using Tapatalk -
Cardboard assisted design I will be switching to quarter inch plate for the frame bracket for the winch plate. Sent from my SAMSUNG-SM-N920A using Tapatalk -
Join the NOAS Facebook group Sent from my SAMSUNG-SM-N920A using Tapatalk -
Im using valvoline import truck stuff. Sent from my SAMSUNG-SM-N920A using Tapatalk
It would make sense to do a similar drop down bracket to match your front suspension. You could even do a 4 link or 3 link too given that that height due to the amount of lift required. Sent from my SAMSUNG-SM-N920A using Tapatalk
build threadish/engine overhaul tips and help
Cuong Nguyen replied to batonveck's topic in General Forums
If youre confident in your skills, port and polish the heads and throw in the stock cams from the vg30s. Sent from my SAMSUNG-SM-N920A using Tapatalk -
Alternator not charging at engine start
Cuong Nguyen replied to colinnwn's topic in 96-2004 R50 Pathfinders
Sounds like a failing voltage regulator. He should have replaced it. It's super inexpensive. Sent from my SAMSUNG-SM-N920A using Tapatalk -
I've posted a link somewhere in a couple of the transmission threads with the guys over in Australia working on a programmable TCU to improve shift functionality. The transgo and the superior shift kits firms up the shifts by redirecting fluid and increasing spring pressure.
Check the wire and sensor. My original was cut up and sensor was faulty from all the oil and grit covering it up over the years.
