JPB
About JPB
- Birthday 04/05/1975
95 SE V6 - custom infant seat mount
Skilled/Experienced Mechanic
30-35
1995
Contact Methods
Website URL
http://
ICQ
Coquitlam, BC
JPB's Achievements
They are way too wide for a 11" wide tire - you should look for a 7-8" wide rim. Your front end will be much happier. JP
From what I have been reading the hydroxy works as a combustion aid allowing a more complete burn of the gasoline therefore equaling a higher volumetric efficiency. As a result you can lean out your air to fuel mixture = less fuel used = higher mpg. Similar to running propane injection on a diesel motor. The cells in this discussion draw 10-20 amps to run so even if you upgrade your alternator to a maxima or quest one you will still gain mpg because your hp to run the higher amperage alternator won't negate the decrease in fuel usage. Lets say you gain 5mpg from adding the hydroxy but lose 1mpg from having to drive your alternator harder, you still net 4mpg. JP
What are your plans for fooling your O2 sensor? I'm thinking of running one of these: http://www.innovatemotorsports.com/products/lc1.php JP
Here's all the info and plans that you will need - all for free: http://www.panaceauniversity.org/ JP
Here's my solution. http://www.bianchiusa.com/08_axis.html Next week there is a new $0.02 carbon tax on fuel - pushing the price to $1.5 / litre (that's $5.70 / gallon). So I'll be riding every day - right now it's three days a week. JP
I just pulled the vacuum hose off of my brake booster and poured it in slowly. JP
I guess I'll just wait until September for a 33x10.5 BFG MT KM2 to come out. I was considering 255/85R16 Toyo MT's. Thanks JP
I'm willing to try with a 7" rim and stock back-spacing. JP
I don't want to do more then a 3" UCA and 2" BL at the most. This is my DD and family hauler. JP
I could do that too but I'm hoping to get away with less lift and trimming by running a narrower tire. JP
Hey everyone, I'm looking for some pics of WD21's running 255/85R16 (34x10.5) and how do you like them on your pathy. Thanks JP
So it seems like allot of you guys are running without mufflers or glass packs - how do you get around the BLM cops? Everytime I have been wheeling in Washington in the spring/summer the BLM are always camped out at the trail heads and not letting trucks in without spark-arresting mufflers. BTW I'm not a fan of loud exhaust on 4's and 6's. JP
I see a white, SAS WD21 on 35's with air bags in PoCo everyday on my way to work - is it someone's here? Here's a pick of my pathy. JP
It's funny you say that. The bug has bitten already. But this rig will stay conservative - no SAS or big meats. I'm in Coquitlam. JP
