Content Count
857 -
8
SilverPath last won the day on February 2 2016
SilverPath had the most liked content!
Community Reputation
87 ExcellentAbout SilverPath
Rank
- Birthday 04/27/1988
Contact Methods
AIM
BuLlD0G SG1
MSN
bulld0g68@hotmail.com
1999 Pathfinder XE >Cragar Soft 8's w/ 33x12.50R15 BFG MT KM1s > Roof rack with basket for my tire and lights. >67" Trail Gear Rock Sliders >1/4" Steel front skid plate >Custom front bumper >AC 2" lift kit and NX4 Spacers
Place of Residence
Vancouver,WA
XE
1999
Gender
Vancouver,WA
7,982 profile views
RainGoat started following SilverPath
I don't have pics of just the mounts but here are a few, I made a few different types of mounts out of Engineering paper all to scale so I could tape it to some sheet and cut it out with my jigsaw. Ended up being the farthest right one that worked the best. Then I bolted in all the mounts lose so I could add a small shim to take out some slop, then I aimed it and tightened all bolts up using some never seize to stop any galvanic corrosion . The door seal actually has a built in channel that I used to run my 14 gauge wiring up the door sill.
Have my curved 40" along the top line of my windshield
I am at Winchester bay this weekend playing in the sand with the bikes. Derek text me if you have a hard date set and Ill see if I can go, I dont come here often anymore. I might also have a 4runner down also.
Mr.510's VG33 Crank Adaptor.
SilverPath replied to conor1123's topic in Solid Axle Swaps, Hardcore Custom Fab
Facebook, He does not make a presence here anymore. -
Wish I could join ya, going camping in OR this weekend!
yup our work trucks are all 550s with 6.turd also. Love that engine to death.... Currently replacing another FICM Cant get rid of them because the market is so flooded, about to do the Cummins swap in it
Trying to find old build thread - help
SilverPath replied to muddfildvaynes's topic in 96-2004 R50 Pathfinders
Not sure on the thread yet, but here I had Johns(PA) PB saved http://s1191.photobucket.com/user/pamountianbiker/library/SAS?sort=3&page=1 -
I just removed the knob and the boot, It is screwed onto the side of the tranny with two bolts and a nut that connect it to the TX
The 96-99 pathfinder flares will bolt onto any preface lift pathy. While they don't have the side holes for the plugs, I used the holes that held on the wheel well lining to mount the flares I had as mine never came with them.
I have a set, however It most likely wont be cheap sending across the entire US
3.75 is what I run. I would not go bigger as it will hit the strut.
From memory so I may be forgetting something. This is also for manual windows since that is what I have, Remove the bolts holding the armrest on, pop the trim piece off the inside door latch handle, Remove the screw inside the latch handle well area, Pop the Clip off the window crank(if Electric Im sure the switch panel comes out and disconnect the plugs and remove possible bolt there also) Then get a Trim removal device (looks like a giant 2 prong fork) and work your way around the perimeter popping the little red/orange clips out
Drill the old holes bigger and tap them for a bigger bolt
Its really not that big of a jump to make it worthwhile, Thanks though!
I have a 1999.0 with a manual tranny and 4.3 gears and 33s, suffice to say I wanted my umph back. I was looking at upgrading gears to say 4.9 so I could bring my highway manners and torque back close to stock. I was told I could simply use Xterra gears and move on with life, I recently came into possession of a front and rear R&P set in the 4.9 flavor. For starters, the Xterra and WD21 R200 front diff are a low pinion setup, this was the first big sign that they were not going to work, however being I had to swap in my lokka anyway we decided to dismantle my case and investigate further. The R50 gears are in fact reverse cut, however that is only because it is mounted in a high pinion setup, the axles still spin the same way when turned. Here is a X pinion and my R50 pinion next to each other for comparison sake.
