Bjarne
About Bjarne
  • Birthday 04/11/1986
    Black Emerald 1994 4-Door LE-V6. Bought it around Sep. 06 and was very well taken care of, with all service records. She Runs like a dream and is a fine show of stock Pathfinder workmanship... for now!
    Nanaimo, BC
    Canada
Bjarne's Achievements
  1. Driving down the road, everything was fine then climbing slight hill it 'popped out' of gear. Won't engage in any gear at all. Fluid is good, bit dirty but good. Whinning noise coming from underneath Any ideas?
  2. With tire's that wide on a pathfinder good luck maintaining traction on any surface like mud ice/snow or wet pavement!
  3. Moved out from Calgary, still working on getting the Pathfinder out too hopefully in Dec sometime, looking forward to touring the island and seeing the places I can get to! Nice to see there's some members out here can't wait to see you on the trails
  4. Can't wait to get my truck out from calgary
  5. One thing I'm always careful about is when removing from 4H/4L back into 2H I always make sure to revers (with automatic locking hubs) at least two wheel revolutions as to make sure the hubs have disengaged. After time the gears inside can become sticky and not disconnect as well, if not properly disengaged can wear prematurely and cause slippage while in 4X4, not a lovely sound, plus wont get you out of sticky situations. This had happened to my previous pathfinder and caused much frustration. P.S. Off road vehicles are designed to go into 4Hi first then the option of 4Lo from there, Neutral position on the "fun-stick" is meaning the transfer case is in neutral not the transmission (placed between Hi and Lo like Forward and revers on the auto-transmission), different but both key components of the drive train. just play around with it, 4Hi will rev like 2Hi but will skip when taking corners on pavement (not recommended for any length of time other than quick test), 4Lo will rev higher with little speed gain (lower gear ratio, more torque to wheels) skips as well on pavement(quick test if necessary), and do not drive in 4H/4L on dry road surfaces for any duration!
