Kr50
Everything posted by Kr50
  1. I will definitely doing this procedure this weekend and let you know how it goes. Also many thanks for the diagrams. It definitely helps a electrical noob like me. If worst case it ends up being something like an ECM thats gone bad. Would another ECM just plug and play from a different car?
  2. So made some updates today. I checked the fuel pump connector and the wore with 4 prongs gets power and the 2prong which is connected directly to the wore leading to the pump doesnt get any power. Slight change in frequency when turning the ignition on. So i checked all the relays and fuses that’s associated with the fuel pump and they seem fine. I pulled the back fuel pump relay panel( next to the amp) and found out theres only one relay. Im guessing theres 2 and one conector was just hanging. I bought another relay and connected that and still no success. What else would factor fuel pump not getting power? Is theres a common issue on pathfinder? Im kinda running out of ideas.
  3. So finally managed to get the new starter. That was not a fun job at all lol. Now it cranks and engine seems to try to start but seems like no fuel coming in. So i pulled a hose from the filter line and turned ignition on and no fuel came out although i hear a buzzing noise when turning on ignition for about 4 seconds and goes out. I took the fuel pump cap off and kept my hand on it while my buddy turned ignition on but there was no vibration just sound from underneath thats hard to pinpoint. Does anyone have any ideas of what it could be? Any places i could check if the pump is working for sure. thanks
  4. Looks like its on the top of my list of things to do when i get the engine started. Hopefully everything goes smooth with the startup.
  5. How common is this? Is it something that needs to be done urgently? Im at 165k
  6. Dash works. All the displays work just not the bulbs behind the buttons and gauges itself. Ill try messing with the dimmer.
  7. I did find that the hood sound deadening has been eaten up in certain spots. But havnt had time to dig deep into it. I will look into it when i get some time
  8. Also found out that the dash lights dont work along with radio. Climate console lights up along with display on the headliner. Just no dash and button lights.
  9. Thanks. After getting it started ive got a lot of cleaning up to do.
  10. I will try tapping it. Starter solenoid comes with the starter as a single unit i assume. I checked on rockauto and theres a seperate drop down for it. Thanks for the reply
  11. Hello all. I just bought a 2002 pathfinder with 167000 miles that was sitting in a barn for the last 3 years. Its pretty clean but has a starting issue im trying to diagnose. I just installed a brand new battery and tried to start it but all i hear is one click and no cranking. Im leaning towards the starter but would like to get some ideas here first. I will post some pics when i get a chance to take some proper ones.
