AlwaysWrenching
Content Count
35 -
Community Reputation
3 NeutralAbout AlwaysWrenching
Rank
1997 stock
Place of Residence
Michigan
Skilled/Experienced Mechanic
36-40
1997
Michigan
Country
258 profile views
Totally stock tires. New transmission filter and fluid. The torque converter locks and unlocks so much it's annoying while driving. Usually a bit of hard acceleration and it stops for a while. It did get better after changing the transmission fluid and filter, but then after about 1700 miles started acting up again. There was a lot of sludge in the transmission. 227000 miles.
The blower motor for the heat and AC does not work on any setting. There is power to both wires going to the motor. However when the motor is hooked up directly - one wire +, one -. It spins just fine. Did the resistor fail?
I bought a complete set from TRQ. They are made in Taiwan. All 4 control arms with new bushing for like $130. So far they have held up great.
I have a 1998 Pathfinder that has been great. So much that my GF wants one. I love the manual transfer case on my 1998. I'm debating on finding a 3.5 Pathfinder with a manual transfer case but I'm not familiar with the 3.5 at all. Are there any disadvantages to the 3.5? They 3.3 is very easy to service and isn't too tight in the engine bay. The truck will rarely see freeway driving so lots of acceleration at 80 isn't as important as torque, durability, and service-ability.
Of topic but how did you repair your sunroof? Any chance you found a gasket you could make work? Mines currently sealed with RV tape. I didn't want to caulk it because the motor is still good.
I ordered these struts from Summit Auto. Hopefully they are good quality. I didn't want to lift it since it's my daily driver and I have a rusty 1988 Bronco that's going to get 35s and have all the sway bars removed. I also ordered AC Delco progressive rate rear coils. Rear shocks are new, just NAPA shocks. Going to upgrade to Bilstiens if I need to. This thing is a little beast. Took it down a 4 wheeler trail today.
Gabriel Struts - Quality?
AlwaysWrenching replied to AlwaysWrenching's topic in 96-2004 R50 Pathfinders
Does KYB make a loaded strut? Strut, spring, etc? The truck has 217,000 and I'm planning on replacing the springs as well. -
I saw Gabriel also makes a pre-loaded strut? Anyone tried these?
I was able to get to it by first putting the spark plug socket on and then attaching everything. I had an inspection mirror and light so I could see in there.
1997 Pathfinder Timing Belt Replacement 3.3L
Did you guys remove the radiator? Was it necessary to remove the AC pump? -
Manual Hubs for 1997 Pathfinder
Yeah I can't see how I'm going to break the Milemarkers with mild off-roading and stock 235 size tires. -
Thanks guys. Ordered up the Milemarkers. Should be here next Thursday.
