UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
zakzackzachary
zakzackzachary last won the day on December 16 2019
zakzackzachary had the most liked content!
1 Follower
    2000 SE (R50)
  • Place of Residence
    Pacific NW
    Kitsap
zakzackzachary's Achievements
NPORA Veteran (3/5)
202
  1. This is kinda the crux of it. It's his shtick. I used to watch them back in the day, but for me it got a little tiring and watching the latest R50 video reminded me of that. Tyler did a little rebuttal video that addresses some of the RCR points, I found it entertaining and good. I like that it exists just as a counter for anyone who runs across the RCR video and has differing opinions.
  2. If OP is handy, they could potentially bench test the starter (or maybe on the vehicle?) with 12V leads. If it seems to be working fine, my next thought would be the ignition switch, maybe.
  3. I've never heard of any aftermarket solutions and most DIY racks utilize the OEM rail that's bolted into the gutter. If it were me my first stop would be to check the local salvage/junk/car yards and see if there's a Terrano you could pull them off of!
  4. I saw a nice green 96-99 Pathfinder on Bangor navy base in WA, if you're out here: lookin' good!
  5. I'll be honestly, I never thought about using it as an added layer of protection, only as a bandaid to a torn boot. That's kinda an interesting idea.
  6. Without looking at value or anything, my gut tells me that if a replacement transmission is less than.... $1500 it'd be worth it to me. Obviously can save money if it's remanufactured, rebuilt, junkyard, DIY, etc. Why that much? Well, it's obviously in good shape and still a good vehicle. You know all the history, one owner, etc. Replace the transmission and I bet you could get many more years out of it. The alternative is you spend more than the transmission on a different vehicle. Either much more on a new vehicle with known history, or somewhat more on a vehicle that runs, but probably doesn't have the same meticulous records/history as yours. Just throwing an opinion out there for ya, you know what they say about opinions
  7. I think you made a solid choice. Mounting my tire carrier is not something I'd even be remotely interested in doing in the street in the rain. Although I didn't need a cherry picker or anything to do it solo, it was still some awkward finagling. I'm sure the resale value on the hitch one makes it a no brainer for your situation, along with the modularity that comes with being able to remove/install it on a whim. I'm a fan of that- my recent Rola basket mounting solution includes some custom brackets I made that allow me to bolt/unbolt my basket for removal in about 5-10 min which is handy for a number of reasons!
  8. Additionally I find this set-up pretty dang good. Only downside is the reduction in downward suspension travel, but that's a function of the heavier duty springs and the fact that we're limited by OEM spec struts (other than maybe OME struts...).
  9. Are you planning on OME HD front springs PLUS a 1" spacer? That might end up pushing it as you'll see. I currently run OME HD front springs plus a 0.5" spacer and I found that was the max I could go. That was after a year of letting the OME HD springs settle out first.
  10. The 9449 + strut combo should work well, but the 2" spacer on the front is typically not recommended. Might be able to run it for a while, but most people prefer to go with an upgraded front spring in an OEM spec strut (like the KYB). AFAIK there's only one upgraded front strut- the OME strut, but they're pricey and harder to come by.
  11. I've been working on diagnosing a similar issue with my 3.3L. Sometimes, almost randomly as far as I can tell, after I first start the engine it'll run rough- stumbling like a misfire. Letting it run a bit, or if I just start driving, it'll go away pretty quick and then idle fine. I haven't yet narrowed it down, but it sounds similar to your issue. I had a knock sensor code, but it went away after I changed out a bad O2 sensor, so the knock code was connected to that thankfully.
  12. Okay so update. Me and @PathyDude17 started chatting and it appears there's more differences in rear shock mount placement and required lengths than I originally thought! Pre-facelift has an upper mount that is slight up/away from the top of the spring mount, and a lower mount that is about in line with the axle. My 3.3L post-facelift has an upper mount like pre, but a lower mount that is dropped below the axle. 3.5L post-facelift seems to have an upper mount closer to the top spring mount and dropped below the axle. We're going to try to gather some picture examples and put together a separate post about it. Just another example of all the minute differences between models...
  13. I have LR 9449's which are just the stiffer version of the 9447's and currently use Bilstein 33-185569. I do have the tire carrier on the back which adds some weight, but I've never had any issue with my bushings or length of stock brake lines yet.
  14. That looks awesome and provides a ton of attachment points, great job! I thought I'd be building one out of extruded aluminum one day, but that's definitely more pricey. Same idea though.
  15. My nose is burning from all the bleach we use at work now. #essential
    1. PathyDude17
      PathyDude17
      Same. Spraying down golf carts with a 5:1 water bleach mixture that has to set overnight
