dat280zxt
Everything posted by dat280zxt
  1. On my 2002 QX4, the Bilstein sleeve in the install kit doesn't fit on the lower axle stud. How did you guys get past that? The old sleeve in the old bushing is also too large for the new bushing.
  2. Original Post corrections// 4x4parts.com Deluxe Kit... and DEATH WOBBLE, not Double. Apologies for confusion. Leaning: Front: AC Springs KYB 335032/3 Excel-G Gas Strut Rear: NRC 9447 springs LRDirect.com Bilstein 5125 shocks 33-185552 any guidance on previously listed Part Numbers? Anyone?
  3. 2002 Infiniti QX4 I did some research, but was hoping for Part Number confirmation. I read a post about the 4x4 Deluxe Suspension kit having possibly a wrong part number and snapping... got worried, so, going by part number. Death Double Fix plus 2" lift 'kit.' Opinions, suggestions? Especially what Additions? -AC 2" springs (is 4x4parts the only supplier at 453.87 shipped?) Amazon.com (will shop around...) Rear: -Bilstein (33-185552) 5125 Series Shock Absorber 2x~71.58 or -KYB KG4163 Gas-a-Just Gas Shock 2x~48.68 Front: -KYB 335032 Excel-G Gas Strut 1x50.64 -KYB 335033 Excel-G Gas Strut 1x65.78 -KYB SM5329 - Mount/Bearing kit w/Boot 2x32.16 -Specialty Products Company 81260 Alignment Kit "14mm camber bolts" 2x19.47 Then... -Front Lower Control Arm Front poly bushings 4x4Parts -Front Lower Control Arm Rear poly bushings Energy Suspensions -Rear Center Sway Bar bushings Energy Suspensions -Rear Pan Hard Rod bushings Whiteline W83395 -8x Upper/Lower Trailing Arm bushings Whiteline W61705A Is a kit with the following suggested? •Front Lower Ball Joint - Qty 2 •Front Outer Tie Rod End - Qty 2 •Front Inner Tie Rod End - Qty 2 •2 x Front Outer Tie Rod End moog-es3466 •2 x Front Inner Tie Rod End moog-ev396 •2 x Front Lower Ball Joint moog-k90662
