2002 Infiniti QX4
I did some research, but was hoping for Part Number confirmation.
I read a post about the 4x4 Deluxe Suspension kit having possibly a wrong part number and snapping... got worried, so, going by part number.
Death Double Fix plus 2" lift 'kit.'
Opinions, suggestions? Especially what Additions?
-AC 2" springs (is 4x4parts the only supplier at 453.87 shipped?)
Amazon.com (will shop around...)
Rear:
-Bilstein (33-185552) 5125 Series Shock Absorber 2x~71.58
or
-KYB KG4163 Gas-a-Just Gas Shock 2x~48.68
Front:
-KYB 335032 Excel-G Gas Strut 1x50.64
-KYB 335033 Excel-G Gas Strut 1x65.78
-KYB SM5329 - Mount/Bearing kit w/Boot 2x32.16
-Specialty Products Company 81260 Alignment Kit "14mm camber bolts" 2x19.47
Then...
-Front Lower Control Arm Front poly bushings 4x4Parts
-Front Lower Control Arm Rear poly bushings Energy Suspensions
-Rear Center Sway Bar bushings Energy Suspensions
-Rear Pan Hard Rod bushings Whiteline W83395
-8x Upper/Lower Trailing Arm bushings Whiteline W61705A
Is a kit with the following suggested?
•Front Lower Ball Joint - Qty 2
•Front Outer Tie Rod End - Qty 2
•Front Inner Tie Rod End - Qty 2
•2 x Front Outer Tie Rod End moog-es3466
•2 x Front Inner Tie Rod End moog-ev396
•2 x Front Lower Ball Joint moog-k90662
