notmeami
    2002 LE 4x4
    Choose
    Denver
358 profile views
notmeami's Achievements
  1. @Mr_Reverse Yes, the scene you have envisioned is correct.
  2. @hawairish Read your can of worms...pretty sure your worms are in my pathy too. Rancho struts SFC spacer lift and new Cardone cv axles. Replaced drivers side cv axle too with no issues but no such luck on pass side. Ordered them a week apart or so I will have to look at them to compare numbers. I'm out of town for a few days but will add my info and picks as requested to your can of worms post. Only re[placed cv axles because tore inner boots on both sides a few weeks after spacer and strut install. I chalked it up dry old boots. Pathy has over 200k miles. Cv axles are so cheap- I didn't want to bother with replacing boots. Figured I'd do it at a later date for spares. Regret disposing of ome struts now... Great job measuring all this out!! Seriously. Great. Job.
  3. R50JR-- I mean that while in 2H (4x4) and the front end off the ground, the cv axle will only spin about a 1/4 turn either direction. This is only on the pass side. The drivers side is cool and spins freely. Mr_Reverse-- Yep. I am referring to the axle as a whole. I realize the spindle runs through the hub. I am referencing when the front end is off the ground that the pass side will not turn more than a qtr turn or so.
  4. What is the deal with this? How to diagnosis problem and fix??
