dezm
Everything posted by dezm
  1. I'm a little confused, are the swing gate kits going to be everything you need to install a tire carrier? Or just parts to adapt a JY OEM tire carrier to a Pathy that didn't come with the OEM one?
  2. You bet, I would also keep your eyes peeled for a bumper from @hawairish and @TowndawgR50 thats supposed to be coming soon. They're planning on releasing a bunch of R50 specific products very shortly. More deets here:
  3. How are you finding the ride quality of the 9449 when unloaded in comparison to the OME?
  4. Too expensive to ship the LR springs over here so they’re up for grabs!
  5. Fedex.com has a great shipping calculator
  6. I’d love those 9448! I’ll PM you Sent from my iPhone using Tapatalk
  7. Do you have a build thread anywhere for this beaut? Sent from my iPhone using Tapatalk
  8. That sounds good enough for me! Cheers man, thanks for the tips.
  9. Gotcha, do you know if most people run these without the bushing on the bottom? It seems to me like it would lead to premature wear of the rubber bushing, but I also have zero experience installing suspension of any kind ?
  10. Yeah I like that I didn't give up any trunk space and that its hidden from potential thieves. Only downside really is that you have to use a low profile sub so you compromise on the amount of bass. But for me it's great, just wanted a little extra thump in the trunk ?
  11. Sorry for yet another question, this setup is exactly what I'm planning on doing shortly. I just got my Bilstein shocks the other day, did yours come with the correct sleeve inserts for the lower bushings? or did you just put the bushing straight onto the shock mount with no metal insert? And are you planning on extending your brake lines?
  12. I've ordered the following sleeves from an industrial store: https://www.mcmaster.com/ I based the measurements off of the Monroe website: http://www.monroe.com/en-US/e-catalog/37204 . Fingers crossed!
  13. When mounting these bilsteins, did you guys find sleeves to go in the 16mm side? Or did you just slide the shock onto the mount with just the rubber bushing? The sleeve kit that came with mine is too small to fit the 16mm mount.
  14. Hey I've just run into this same issue. I can't see the photos you posted but how did it work out running the shocks mounted with no eyelet between the bushing and the bolt? Did it cause any issues?
  15. I’d love to hear what you think about the difference in ride quality from the OME MD! Sent from my iPhone using Tapatalk
  16. I know you said you’d prefer not to go this route but here’s a photo for reference if anyone else is interested. I removed the plastic liner and left the lid on top of the sub for protection Sent from my iPhone using Tapatalk
  17. I put this low profile one in the rear cubby, works great. I have enough room beside it for a tire repair kit and some little bits. Rockville RW10CA 10" 800 Watt... https://www.amazon.ca/dp/B019Z3R582?ref=ppx_pop_mob_ap_share
  18. Hey guys, does anyone have any experience using these? http://timbren.com/blog/products-page/nrpf4a/ found another topic that someone had asked about them but people were mainly referring to the xterra and wd21 versions. looking to replace my completely shredded stock bump stops and thought these would be a nice upgrade, I just don’t want them to mimic airbags too much (stiffen the suspension/prohibit flex). *EDIT: Damn I didn’t realize they were $200+, that’s a lot for 2 chunks of rubber...
  19. I like the Firestik mounted on the tail light guards! I've got some on order, might have to do the same.
  20. Gotcha, yeah I’m planning on staying away from spacers in general. Going to be trying out the 9447 with OME HD fronts in the next couple weeks. Hopefully the extra inch or two in the rear doesn’t make my 31s look too tiny! Sent from my iPhone using Tapatalk
  21. Thanks! I’m also to curious to hear people’s opinions on the change in unloaded ride quality going from OME MD in the rear to 9446/7. The 9447 LR springs are a higher spring rate than both stock and OME springs no? Sent from my iPhone using Tapatalk
