Content Count
16 -
Community Reputation
8 NeutralAbout MichaelAndrews
Rank
- Birthday 07/30/1988
2004 SE
Place of Residence
South Carolina
2004
Gender
South Carolina
Country
I'm averaging about 15mpg but i can have a heavier foot at times
DIY winch bumper 'builder' brackets
MichaelAndrews replied to hawairish's topic in 96-2004 R50 Pathfinders
Still following everything looking great hawaii! -
Land Rover rear lift spring install
MichaelAndrews replied to Bax03SE's topic in 96-2004 R50 Pathfinders
https://www.lrdirect.com/NRC9446-Coil-Spring-90-Fr-Rh/?keep_https=yes -
Flushing cooling system 2003 Pathfinder
MichaelAndrews replied to Micallen's topic in 96-2004 R50 Pathfinders
That should be fine, you may have to uncap the nipple by the firewall to get any air out of the system though if you flush it. I learned that when I replaced my radiator and filled it up, my truck would then overheat... I uncapped that and revved until coolant came out. All clear- 1 reply
- 1
Will be following your progress I know it's prob a tough job but will be here for moral support and of course pics so I can copy hahah
They'll fit fine using a normal tire, I used that size in a big beefy A/T tire and it rubs slightly, my suspension is a little worn however
Nice work, take your time I'm sure the community here appreciates you trying to pave the way for others like myself, less inclined to pull something like this off -
R50 engine replacement possibilities? diesel or v8
MichaelAndrews replied to harddownshift's topic in 96-2004 R50 Pathfinders
Ouch, move a few hours north here to SC and you won't have that issue anymore! Haha -
A 5.3 lifted out of any GM SUV would be a win win, cheap and easy to build for more power -
Can't wait to see what this turns in to for perhaps adapting an XJ bumper -
Interested buying a house end of March so I couldn't buy until April but I def will once i close and move -
Awesome news! -
I would be in for mounts if I could mount up an aftermarket JY bumper with winch mount to it -
Nice, take a pic when you get that all installed -
Yes, I keep going back and forth whether or not I wanna do the 2.5 vs 2. Figured worse case scenario ill go through axles eventually. I work at a garage so access to lifts, tools, and master tech's to help me is plentiful so if i have to swap em so be it Camber bolts K5330 Springs 51302 Mounts K90301
