86
Everything posted by RainGoat
Dbl post
Personally, I find the video incomplete. It sounds like IronMan tried to engage the owner but he wasn’t interested in providing them information. If I were them, I’d probably be done there too. I wish we had a write up with the actual facts. Consequently, if the IronMan springs are coming, I’d wait to get too worried as I’m not convinced you won’t be okay or that IronMan won’t back their product up. That said, no real reason not to go with the Dobinsons. Personally, I very much dislike IronMan’s vivid green.
The sides of a rack really serve only 2 purposes - to keep stuff from sliding off & to mount things like lights, awnings, etc. Having run a Yakima Basketcase for over a dozen years, just an inch or two will keep your load in place if it’s properly secured down.
Hey, are you looking for a fairing? You might see if CBI/Prinsu sells it separately - I bet they would if you call; but the dimensions would need to meet one of theirs. There’s this one I used on the 4Runner - but it’s pretty shallow & probably too wide. https://www.lfdoffroad.com/catalog/brackets-mounts/wind-faring A Yakima or Thule one might work but that’s alot to pay for plastic. If you make a custom or buy a premade rack one, keep in mind there are versions that integrate a single row LED light bar slot if that’s something that might interest you.
Huh, wonder why he wouldn’t get the fender to hub measurements. I’m surprised he didn’t take them, I always take fender & hub measurements. That said, they definitely don’t look like they’re giving him lift. Tough to say - the spacer sure confuses things. Not sure why he threw the spacer on without trialing it first. A 1.5” spacer with any notable lift wouldn’t have been a great idea anyway. If he won’t even bother doing the installed fender to hub measurements, I’m not surprised IronMan isn’t bothering to move forward. Kind of too bad for everybody.
Is the OP a NPORA member? I heard Ironman was reaching out for measurements & he wasn’t collaborating with them. Kind of a bummer all the way around.
Yep, they’re a reputable brand for Toyota. I’d put them as a brand of choice for a moderate build. They’re most likely what I’ll use for a 3” lift on our 5thGen 4Runner. No real complaints in the T4R world.
Just go to his build thread - it’s highlighted on post#90 - though there is some foreshadowing earlier in the thread. In fact, he had to try a few shops before he got one that could do it correctly - and it turned out they didn’t either. I’d recommend anybody take the strut alignment picture from [mention=1343]XPLORx4[/mention] with them to the shop as that error has been documented several times in this forum. In this small world, [mention=37543]TowndawgR50[/mention] was at my place when [mention=41986]zakzackzachary[/mention] got hold of us. I’ve since actually visited the exact spot of the failure on the WABDR. Do as you see fit, just trying to help & keep everybody safe. One of the best aspects of this forum is everyone’s candid descriptions of their struggles, triumphs & failures. No reason to make the same mistakes twice.
Lots of us do regular JY trips & could possibly snag you one ( or some, in case you want spares). I find the JYs sometimes have unreasonable prices though (I’ve left a cup holder adapter at the register before when they wanted >$12 for it). Consider posting what a cap + shipping would be & we could keep an eye out for you.
It’s addressed in better mechanical detail in other threads but [mention=41986]Zakzackzachary[/mention] documents his failure due to leaving it out in his thread (Post#90). The struts alone have several instances of documented incorrect installation by garages in NPORA - in reviewing the above thread, I note he had trouble with some local shops as well. I’ve been passing along@XPLORx4 strut alignment pic for years now as that’s another common error. I would double check any shop’s work, especially for such a safety essential component.
Old plastic breaks easily. A JY is going to be your cheapest alternative- though I admittedly don’t see those racks there very often.
Constant or Variable Rate Springs
RainGoat replied to AR97Pathfinder's topic in 96-2004 R50 Pathfinders
We’ll need more knowledgeable people than me to comment. I will note; however, that lift is relative. 0.5-0.75” areoften quoted for OME but I’m guessing that’s vs brand new OEM. My lift was substantially more but it was from a 17yo suspension. I would expect though that you’ll be in a safe zone with regard to CVs. I’ll let others address rear top out though it sounds like you should be okay. I must have missed the rear shocks you’re intending- I’d list the spring with specs & spring rate as well as the shocks. Your Ironman experience will be interesting. It should be a safe bet but it’s new here in the US so tour experience will be pioneering. -
Front Notes: Nissan R50 OEM Springs: 115”/# Spring Rate 5" Inner Diameter Front Springs: Dobinson Ironman 4x4 Part#NISS034B (https://ironman4x4america.com/nissan-pathfinder...-0-110lbs) ARB OME AC TJM King Dobinsons (https://www.dobinsonsdirect.com/products/dobinsons-pair-of-front-coils-for-nissan-pathfinder-r50-1995-2005c45-168) -
I’d go with LR rears in a heartbreak - you’ll have to consult the threads regarding height. Each height is available in a medium & heavy duty spring rate. -
As for the spring sleeves, you can reuse them - I did; however, mine were mostly worn through (literally worn away to non-existence in large spots)& I wish I’d had replacements. I rotated mine & others have replaced with hose. Honestly, I’m not sure where you get them but I wish I’d had some handy - it’s the one thing in the rebuild I felt we did suboptimally. -
Need help Mild Facelift for 2004 R50
RainGoat replied to 04Pfinder's topic in 96-2004 R50 Pathfinders
KYB struts are fine, noone has had a problem with them. There may be some improvement in road manners with the OME, but its incremental & probably imperceptible paired with AC struts; plus they are significantly more expensive. I believe it was [mention=38818]micahfelker[/mention] who experienced a failure with the Moog strut bearing, not KYB. Here was my part list: OEM Replacement Parts Strut Bearing [54325-5V000] $48.54=$24.27x2 Spring Seat [54034-0W000] $45.42=$22.71x2 Bellows & Bump Stop [54050-0W002] $38.86=$19.43x2 Did NOT use: Upper Seat Rubber Bumper (NOT rubber) [54057-0W000] $22.50=$11.25x2 $173.17 ($155.32+$17.85s) infinitipartsdeal.com Wish I had new rubber/plastic to go on the bottom of the spring but I just rotated my old ones since I did not. I believe@hawairish improvised with hose. @02_Pathy & [mention=39745]stpickens[/mention] have excellent examples of 2” lifts; prior to their SFDs. 2” is all you really need & can make a great build. While manual hubs are all the rage, many of us, particularly the ATX14A trucks, are still running autohubs. In a part-time 4x4 truck there is no reason not to install them; but I wouldn’t get hung up on it. If you’re not spacer lifting, keeping it at 2”, & not rock crawling, you’ll probably never need new CVs but if you do, the manual hubs make it possible to replace them without removing the tire. Having owned my truck since new in ‘02 but having just started to refresh it about 4 years ago, you’re in for a treat. Just freshening the suspension alone will make it infinitely more pleasant to drive. -
Photos from[mention=37543]TowndawgR50[/mention] I can’t tell you how much I like his set up. The dust/chase lights work great too.
@towndawgR50 was able to get TAP plastics to cut an amber lens for his existing light bar for a very reasonable price & it performed much better than film.
Using only 4 connection points should help accomodate the rocker in the roof/rails. If you use more, you’ll have to have different heights. I have 8 attachment points, which is arguably too many as you want the roof to be able to flex & you probably want your attachment points to give before the rails or your roof. I want to elevate my rack about 1.5cm using some small aluminum towers but each pair of towers needs to be a different height as the curvature is asymmetric. Another FYI, you might want a sloped front to decrease wind resistance to mitigate the effect on your mpg. Also, that box front is likely going to create alot of wind noise. Finally, consider an amber light bar.[mention=37543]TowndawgR50[/mention] windshield LED bar was essentially only usable at low speed due to all the hood light reflection. He then redid it with an amber lens and it’s a world different. It still casts tons of light but isn’t bothersome to the driver & even okay to have in your rear view mirror. All the while, bright enough that I was essentially using it to see myself when he was ahead of me. Totally convinced me to go amber in the future.
Westwood or Santa Monica, 1989 or 90 Ha ha, 30 yrs ago, still pisses me off
If you want to burn alot of time, here are some extensive battery/alternator threads. I don’t claim to understand any of it. https://www.toyota-4runner.org/5th-gen-t4rs/216665-voltage-booster-31m-agm-battery.html https://forum.ih8mud.com/threads/alternator-voltage-booster.503895/
Ah yes, QX4! Definitely read the threads on Lokka. In the part-time transmissions it’s an easy decision- alot tougher if you have the ATX14A. I bought my Pathy 18 years ago, primarily based on the engine & handling, so those things ate still paramount to me. Also, I live in the PNW, so I use the AWD most of the time. I also prefer it for the vast majority of offroad driving as it eliminates the understeer of a locked center & I find I rarely really need 4Hi or 4Lo as most offroad is really just dirt track. I didn’t care for the Lokka on road but it sounds like yours will be more a crawler than an overlander. The Lokka works fantastically though - offroad, I don’t know of anyone who isn’t happy with it. It actually works great with a good rear LSD. Unfortunately, ‘03 & ‘04 have pretty light breakaway points so you may want to read the thread on repacking them.
- 13 replies
- 1
- infinitiqx4
- infiniti
(and 1 more)
Tagged with:
