Years ago my dad was given the 95 Pathfinder that needs a water pump. After replacing the water pump and timing components we put it on a trailer and up it went to Northern Ga. I will be doing the same and sending it south to me and have a few items that I will need to sort out.
Speedo not working (replaced speed sensor but still not working. May pick up a used cluster and heck then).
Tranny issue (when cold you have to drive in 2 or low. After a mile it will shift fine in D. Otherwise it will slip. Will drain fluid, change filter and add cooler).
Factory Alarm (not sure if it has one but will do research on Vin and check)
Change Fluids (aside from engine oil and tranny will do both diff's and transfer case)
Will plan on adding some wheels and perhaps a small lift and suspension. Plans are for this to be a weekend family hauler with some light off roading. I have a company car and have a daughter going into high school so she will take my G37 sedan. Plan on getting the Pathy towed down sometime in the summer so will post pics then.
If anyone has suggestions on the issues I mentioned please chime in!
Thank you!
