Muncie
Everything posted by Muncie
  1. If it turns out not to be the fuse...look up the posts on steering will clock ring contacts. Those things wear down. I don't know if it would cause the flicker or not, though. Sent from my iPad using Tapatalk
  2. Turned out to be a stuck float valve in my brake fluid reservoir. Just unstick it and fixed. Worth a look!
  3. I had the same door ajar light problem. I added a couple of washers to both bolts on the hatch latch. Didn't work. Added a couple more washers, going right to the limit of how many washers you can have and still have enough exposed thread on the bolts for them to reattach. And it worked! So I guess my tip would that washers are not all the same thickness. You want to boost your latch by about 3/16" to 1/4".
