36
Alkorahil last won the day on October 16 2014
Alkorahil had the most liked content!
About Alkorahil
- Birthday 12/17/1973
1995 Pathfinder XE 4X4. Gold color. All XE Options. Roof Rack, Roof Lights, 31" Tires. CB radio. Alpine CD player/Alpine Speakers. Bilstein shocks, Borla Exhaust, Magnaflow Cat, Taylor Ignition wires, NISMO Air Intake, Suspension, Brakes. 1995 Hardbody King Cab SE, Long Bed V6 4WD. Black. 31" BF Goodrich TA/KO. ProComp Shocks, Nismo Brakes. Baja rear pumper, side steps, CB radio Magnaflow Cat, Taylor Ignition wires, NISMO Air Intake, Nissan Bed Liner. 2006 Subaru Impreza WRX STI 6sp MT with too much stuff to list.
Skilled/Experienced Mechanic
36-40
XE
1995
Contact Methods
Website URL
http://
ICQ
Yahoo
alkorahil
Gender
Dallas/Plano, TX
Country
Interests
Pathys, Hardbody pickups, Chevy LUV, RC models, my pet parrot.
19,415 profile views
Alkorahil's Achievements
NPORA Old-Timer (5/5)
301
Kenosangel started following Alkorahil
When replacing the injectors you need to replace with either blue or black. It is not good to mix and match injectors.
Need help with my path (3 distributors)
Alkorahil replied to theworks001's topic in 96-2004 R50 Pathfinders
I have known several friends and customers who have gone through many aftermarket distributors just like you are doing before getting a good one. So many of those aftermarket brands are not built or rebuilt very well. Not saying this is your exact issue but it would not surprise me either. Out of curiosity what brand is it and where did you get them? -
I don't have a Service Manual that goes back that far and cant find it in the archive. I can tell you on the 94 and 95 models the fuel sender unit is 1.5 ohms and the fuel gauge is 3.8-8.5 ohms full and 83.6-93.6 ohms empty.
28515-43G10 supersedes to B8515-43G85 It fits only the Pathfinder from production date 08/89 to 10/95 and Hardbody Truck from 08/89 to 08/97 with power windows and power door locks. The 240 amplifier is a totally different part number.
The small ones with the brown sockets are Nissan P/N 24860-40F01. They are 14 Volt , 1.4 watt
Here is Nissan's overly complicated part description for a pin stripe: Exterior Decoration Moulding Trim Strip Line Sticker
Is my Oil filter for terrano D21 Z24 engine ok?
Alkorahil replied to patrickt's topic in 86.5-89 WD21 Pathfinders
Hi Patrick, A carburated Z24 should use part number: 15208-W1103 which changes to part number 15208-W1106 but as kingman said, part number 15208-H8990 would probably work and be ok if it was all that you had. You are correct that part number is for the old 2.0L engines. -
PM me your truck's VIN and all the info you can from the donar and I can help narrow things down for you.
PM me directly the vehicle VIN and I can get you a quote and parts availabilty
Passenger side is super easy and straight forward. Unhook the harnesses and hoses that connect to the valve cover, take a phillips screwdriver and undo the screws holding the valve cover on, being careful not to loose any of them, pull the valve cover off. remove and replce the seal.
I would look at the valve cover gaskets and the rear main before the oil pan. As said above, oil can leak down from higher up and collect on teh pan, making it appear to be the pan. Nissan says it should take 5 hours. ASE standard rate that most shops use says it takes 6.6 hours.
Deep down you know this was the high point of your day, if not week It is OK to admit it.
Need Some Assistance With Catalytic Converters
Alkorahil replied to AirChime's topic in 96-2004 R50 Pathfinders
I am very sorry that this happened and not pleased to hear that this happened here at all, and have let it be known. Who was it in the Service Dept that you spoke with? I am here 9-6pm M-F in the Parts Dept here. If you need something, please come see me and I will do what I can to get things done for you. You can also call me in the parts dept. I am here to help as I can. -
If this is a 4WD Pathfinder, that would unfortuantely be about the right amount of labor hours to remove/replace/reseal the engine oil pan. There is a lot of stuff in the way that has to be removed first, then put back on. Is he certain the leak is from the engine oil pan and not something else?
