101
Everything posted by mjotrainbrain
Been a while since an update, but it drives good now! Not that I've driven it a lot in the past few weeks...thanks Corona. New rotors all around solved all of the shaking issues from what I can tell, and a rebuild on the parking brake made it work; some bits were entirely missing, and the rest was well worn. Also have some DuroBump bumpstops up front, which has the suspension at a point that I'm happy with for the time being. Put a radio out of a 2007 Scion TC in to replace the Jensen head unit, as it was buggy and didn't match the rest of the interior very well. Also put on a new passenger front wheel bearing and ProComp Series 69 wheels after I had a tire fall off during some New Year's wheeling. Done a few other odds and ends since, but mostly been trying to just keep it in good shape and enjoy it. Also has a 1" body lift and a full factory exhaust now.
Here in Michigan lots of people are staying inside like they're supposed to, but there's also plenty who aren't. I work fast food and that's considered "essential" so I still have some income thankfully, although reduced hours. It's strange not driving to class or anywhere else. Getting lots cleaned around the house and hoping to kill some time with wiring projects on the 4Runner soon.
But only very very small ones, from what I've experienced a pic will only fit if you reduce its resolution hugely.
March 2020: mrelcocko *Pending official border.
Congrats @Mrelcocko! *Pending official border.
- 1 reply
- 1
Photos on this forum are a little different than what you're probably used to, you have to host them externally. There's a few different how-to's and informational threads, here's one:
PathyDude's R50 Projects (03 SE 4x4)
mjotrainbrain replied to PathyDude17's topic in 96-2004 R50 Pathfinders
Another excellent video Tyler! I'm looking forward to seeing you tackle that obstacle at the end again in the future with more upgrades. -
Since the strut overhangs the inner edge of the tire (lower coil bucket, should be pretty easy to see if you peek in there), maximum diameter is very critical. As @R50JR said, 31" is your max with regard to that. If you want to retain your current wheels when you get larger tires later on down the road you'll need spacers. As far as fitting without trimming the fenders or bumper, 31's may require some trimming, but if so it won't be a lot.
That's a cool build you've got going! What are your plans for the rear tray? Just gonna do a flat deck, or something more elaborate?
I believe that orientation is making the camber worse, but it's been a minute since I touched R50 suspension. I'd definitely say it's worth trying it rotated 180°.
Not unusual, it's a *fantastic* little pocket for junk to collect in and rot through. Yaaaaaaay rust!
That depends, did you install the camber bolt on the top hole or the bottom hole? In any case, it should be easy enough to loosen the bolt and rotate it 180° to see which way is correct. Even without putting the tire back on you should be able to very clearly see the knuckle change angle.
Well I'll de darned, Dobinson's does in fact make a small lift. Couldn't find the link to the Lovells one @RAW444 mentioned but if he was right about the Dobinson's I'm sure he was right about that too. Dobinson's stuff is very highly favored in the 4th gen 4Runner community, in many cases higher than OME, so I'd put a big thumbs up for that. https://www.dobinsonsprings.com/nissan/niss-79/kits
Bumper plastic, and commonly also a bit of metal on the fender right by the rocker panel. I had to take a small triangle off mine in that area.
If @Mr_Reverse's suggestion doesn't work, only other idea I've got is to start cutting.
I agree with everyone else, with the new glass in it's really not bad! A couple body panels from the junkyard and it would honestly look pretty excellent. Really jealous of how clean your strut towers are too! Looks like you've got a good setup going for it.
I have 1aauto sway bar end links on my 4Runner. The parts are fine but the nuts they included were junk. I wouldn't trust any significant parts from them. With discount codes you should be able to get KYB stuff from Advance Auto or something like that for a comparable price.
There is very little information about that generation Pathfinder on this forum, as they're not optimized for offroading from Nissan really in any way, and this is a primarily offroad forum. All of the discussions thus far (very few) are here: http://www.nissanpathfinders.net/forum/forum/72-2013-present-r52-pathfinders/ As far as a lift, the only suggestion I would have is getting a spacer lift custom machined, just then you'll have to take the plunge to experiment with if the CV's will survive and if it will even be possible to align it, let alone if any of the car's electronic systems will get fussy.
I dig that red! I've seen your rig on IG too, it does well!
Looking for inspiration for my 2001 Nissan Pathfinder LE
mjotrainbrain replied to 01NPLE's topic in New People Start Here!
First of all, nice looking Pathy!! 15's will fit, but it's kinda situational. Steelies tend to be much more likely to fit than alloys. I had ProComp Series 51 15x8 3.75" BS on my QX4, looked tough IMO. For the OP, I'd suggest getting either 15's or 16's, whatever you think fits your budget (consider tire price too) and local availability better. Seems like tires for 15's are becoming less common as new 4x4's get bigger and bigger wheels stock. Pics here:- 6 replies
- tire offset
- new builds
(and 2 more)
Tagged with:
That rack looks sharp on there!
- 3 replies
- 1
- pathfinder
- terrano
(and 8 more)
Tagged with:
Lots of info on this already covered in there. You just gotta sift through it. To summarize, you can fit 32's with some trimming on a 2" lift (springs every time over spacers), you'll want 15x8 wheels with 3.75" backspacing or 16x8 wheels with 4" BS.
READ AND FOLLOW THE RULES! NOMINATIONS AND POSTS NOT CONFORMING TO THE RULES LINED OUT BELOW WILL BE DELETED WITHOUT NOTIFICATION. 1. You can nominate only Pathfinder/Terrano/QX4 trucks belonging to Registered NPORA Forum Members. New members will have to wait 3 months and have a post count of 100 before they can be nominated. Members who are banned, currently on suspension or for 1 month after their return from suspension will also be disallowed. (If you are banned you won't be able to be nominated for 2 months). 1a. Include the name of the NPORA Member who's truck it is that you're nominating (even if it is yours) 2. NO FAKE OR JOKE ENTRIES. 2b. Only original, unaltered photos with out graphics, advertisement or watermarks will be accepted for nomination. (Actual permanent stickers are allowable.) 2c. Final acceptance of TotM Nominations pics and winner submissions is at the sole discretion of the NPORA Moderation Team. 3. First 20 nominees are up for consideration and the nomination thread will be closed after the 20th submission or the 20th of the month, which ever comes 1st. Voting will be from 21st-31th. 4. One pic per nomination post, pics must have at least 640x480 of usable image space for use in the in the official boarder in the event that it wins the popular vote.All nominations are subject to the approval of the Mod Team and all decisions are final. Try to make it a good one or nobody will vote for your nominee! A recent pic is preferred but if the Pathy is still in the same shape as your last pic, go ahead and use that. An offroad setting or action pic is also preferred, but not necessary. 5. Only one truck nomination per member per month. 5a. If multiple people want to nominate the same truck, it is up to the nominee to decide on which pic to run with. In the absence of the nominee, the decision will be made by NPORA Moderating Team 6. Winner gets 3 pics of their choice of their Pathfinder pinned in the TOTM forum (PM me the links please) and is ineligible for the remainder of the calendar year. 6a. A Member can only win once a year - multiple pathfinders does not mean multiple wins. 7. No post whoring. 8. Not reading these rules may result in a zombie attack. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ TOTM: THEMED MONTHS The idea was put forward by packie88 with then intention of getting people out in their pathys to get themed shots. It is only each alternate month that is themed, so you can post up whatever pic you want in the in between month (Some people will never see snow). It is a kind of rule, but a loose one. For example, water crossing nominations may be considered if there is a mud crossing, the truck is in water, or crossing the road in a torrential rainpour. If you post up a pic with no water in sight, then that will be removed. Below are the monthly themes: January Anything goes February Snow pic March Anything goes April Water crossing pic May Anything goes June Sand pic July Anything goes August Flex pic September Anything goes October Sunset pic November Anything goes December Mud pic This nomination thread is open through March 20 or until 20 submissions are reached (whichever comes first).
- 3 replies
- 1
- pathfinder
- terrano
(and 8 more)
Tagged with:
