Johnson2985
About Johnson2985
  • Birthday 02/09/1985
    1998 SE
    Northern California
Johnson2985's Achievements
  1. Nevermind, just read that the distributor shaft wasn't rotating indicating broken timing belt Sent from my HTC6535LVW using Tapatalk
  2. Have the distributor checked, my 1998 was starting then dying after less than a min then wouldn't start at all, it seemed like a fuel issue until I ended up taking it in. Sent from my HTC6535LVW using Tapatalk
  3. Hello all! Been a member for a year now when i first got my pathfinder (1998 SE, manual trans, originally from Canada) but this is my first post. I bought the pathy in Texas, but now that I'm out of the Army i moved back to California. The forums here are extremely helpful, but i encountered a problem that I'm sure you guys can help me with. When i bought it the SES light was on but everything was emissions related so i kinda just ignored it , the codes were: P1444, P0141, and P0335. Now that I am back in California I have to pass smog, but only one time, not yearly like other parts of the state, but anyway for P1114 I cleaned the valve and installed a small fuel filter to keep the carbon pieces from clogging the purge valve again, and for P0141 i replaced both of the downstream o2 sensors. Where my problem lies, and where i need some advise on where to post for help, is the P0335 code, after finally locating where the sensor is supposed to be, I saw that it is completely missing and the wiring harness has been cut off. I somehow need to source a heat shield, wiring harness, and bolt. Someone please point me in the right direction, thanks in advanced.
