61
Everything posted by Mrelcocko
I replaced my entire front suspension. Also replaced both axels. I didn’t replace wheel bearings. I replaced inner and outer tie rods, swaybar bushings and links as well. Anything that had to do with the suspension I replaced.
Thank you. I’ve enjoyed every minute with her. A lot of elbow grease, time and money, but she’s been well worth it.
Put a new cheapo Dual deck in. I’ve had her now 6 years and have loved every minute. Sent from my iPhone using Tapatalk
97 Quey with Bosch Oscar fog’s recessed into the grill. Easy add on. The grill is actually still one piece. Sent from my iPhone using Tapatalk
Well to my surprise it stopped. Has not done it in 3 days so maybe It worked itself out somehow. Thanks for the help guys I really appreciate it. I didn’t feel anything either when turning the wheel. Sent from my iPhone using Tapatalk
The rain hasn’t helped any. When I get a dry moment I’ll check these things. I appreciate all the help.
I had an alignment done about three weeks ago and today I noticed whenever I turn left and then turning the wheel back straight. I feel a pop. Can anyone think of what it might be? I feel it through the steering wheel. Thanks for reply’s ahead of time . Sent from my iPhone using Tapatalk
Possibly for DVD player or CD changer. Sent from my iPhone using Tapatalk
'97 Pathfinder A/T with an odd speedometer issue
Mrelcocko replied to thegenericguy's topic in 96-2004 R50 Pathfinders
How hard would it be to put a 98 Cluster in a 97? The 98 has the digital odometer read out and the 97 has the analog? Would it be simply plug and play? I’m having the same issue with my speedometer working sometimes and others it’s not. I can reset the trip and when pushing hard on the trip reset sometimes my speedometer will start working. Really curious about switching a 98 into my 97. Sent from my iPhone using Tapatalk -
Exactly what was the reason. I’m not trying to sound like a jerk just curious what’s the benefit of it having an electric fan? Sent from my iPhone using Tapatalk
Your welcome. This group is the go to when your having problems with your R50. There’s a lot of good people here and the information is infinite. Much better than Facebook any day of the week. Yeah I’m an East Tennesseean through and through. Sent from my iPhone using Tapatalk
The Ignition signal p1320 is the distributor or a problem with it. Have you set the fast cam idle by chance? Also have you messed with any screws on the throttle body? I recommend downloading the EC section of the fsm to help you diagnose some of your problems as well. Sent from my iPhone using Tapatalk
Thanks for the reply’s. I found it to be the back glass lock mechanism tab wasn’t seating properly.
98 cluster died will a 95 work or can i make it work
Mrelcocko replied to pbilt's topic in 96-2004 R50 Pathfinders
Can you take a cluster from a 97 Qx4 and install a cluster from a 98. Analog odometer to digital odometer reading without rewiring because maybe airbag light is in different place? Sent from my iPhone using Tapatalk -
Thanks guys for the responses. Last week I had to change out the rear glass hatch striker mechanism. Remove the back hatch interior cover taking out 2 screws 10mm then just pull fast and hard and it will come right off. Make sure the glass hatch is open so you can fully remove trim piece. Anyway after I installed the used striker I pulled out of a doner Qx4 everything worked fine for a week. Now my back glass hatch switch isn’t working the hatch and the rear wiper is inop. I checked the rear wiper wiring diagram and the hatch glass switch diagram and all fuses relays/amps are good. I can only assume that the reason neither one are working is the control unit I think the Smart Control unit or whichever one it is thinks the back glass is open hence the reason the rear wiper isn’t operating. I know the rear wiper won’t operate if the back glass isn’t shut completely. It doesn’t make since though because it worked for a week now it’s doing this. I also noticed my anti theft security light isn’t blinking like it should when locking all the doors. It’s acting like it isn’t setting the theft system. My lights flash upon locking with the remote but the security light never goes solid for a few seconds then into the flash pattern. It blinks like a door is open all the time. It’s really strange. I had to replace the drivers side door lock mechanism the one inside the door with the rod attachment about 2 years ago and noticed after I done that if I locked with the remote and then used the key to unlock drivers door the alarm would go off. I figured was due to using one from another QX4 is why the alarm would go off when using key in drivers door it wasn’t original mechanism to vehicle but I’m not sure why it would have started doing that. Maybe someone knows? Sent from my iPhone using Tapatalk
How many remotes can be programmed to a 97 QX4. My doors will lock on there on unless I’m right in thinking someone has a remote programmed other than the 2 I already have programmed. Sent from my iPhone 8 Plus using Tapatalk
I love the look. All that really matters is if you dig it. Sent from my iPhone 8 Plus using Tapatalk
Would the throttle position sensor have anything to do with acceleration and the way the trans acts? Curious because I was told once by a mechanic that throttle issues and trans shifts have a lot to do if the TP sensor is set correctly. Sent from my iPhone 8 Plus using Tapatalk
I was having the same problem, but I glued mine on. Well I used some bathroom grade caulk. That way if I ever needed to remove it without breaking the cap I could do so. Sent from my iPhone 8 Plus using Tapatalk
Hey guys figured someone in here would be able to answer my question I’ve been driving my Qx4 lately And today I used the AC and drove a little bit around town went to the park came back home I was walking by and put my hand on the passenger side fender and it was almost too hot to touch the driver side was the same way so my question is how much heat is too much is it normal for the fenders to be extra hot while running the AC? Sent from my iPhone 8 Plus using Tapatalk
Qx4 @ dusk in East Tennessee Sent from my iPhone 8 Plus using Tapatalk
Thanks guys I appreciate the help. Sent from my iPhone 8 Plus using Tapatalk
Hey guys on the 3.3 it calls for 87, but would it hurt to put anything higher in it? I’m asking cause my girlfriend has over a dollar off a gallon and she has a 2000 Maxima that takes 92. Sent from my iPhone 8 Plus using Tapatalk
