colbywan
Everything posted by colbywan
  1. Nice work! I plan on doing something similar some day when I have more time.... Maybe next spring.. hmmmm....
  2. Idk Adam maybe u were high???? All I know is HID IS FAR superior to non HID IF setup properly.
  3. Are you talking about an older pre-projector style headlight maxima, because then I could understand what u mean. Otherwise a proper HID setup is FAR superior in every way to halogen. Especially during inclement weather. -Colby
  4. If you really want HID's plus the actual REAL added benefit then this buy the euro clear lexan / plastic headlights then modify them like this guy did to his tacoma. It's what I will be doing someday. http://www.tacomaworld.com/forum/2nd-gen-tacomas/62898-hid-retro-fx-r-bi-xenon-4300k-bulbs-gatling-shrouds-complete.html He got his parts here http://www.theretrofitsource.com/index.php -Colby
  5. colbywan It's been ions since my last nomination of meself so here's 1 for the pool!
  6. Installed new vinyl on the work trailer today to match the vinyl on my ZAV yay!
  7. Installed new vinyl on the work trailer today to match the vinyl on my ZAV yay!
  8. I have a limited slip in mine now, it's not open. Can I still swap parts?
  9. Hey MY1Path, do u think I would be able to use this third member with my carrier? Then I would just sell the locker. Because I do need these gears for my pathy to match the ones I bought already. Thanks!
  10. Hmmm.... Ok, thanks for you input MY1PATH I really appreciate it! -Colby
  11. ShiZz!! So there's not much else I can do then eh? How creative would I have to get to get this to work? So the complete axle is to long to re-weld all the brackets from my axle, or is that just to much of a PITA??
  12. I have a 94 pathfinder with LSD. I found for sale used a complete H233B rear axle from a first gen xterra 4.9 with an ARB locker. I am hoping that there is a way to buy this axle complete and take the third member or certain parts and use it with axle or my carrier and be able to use the locker?? This is the ratio i REALLY want and the locker is a HUGE bonus!! I already bought a ring and pinion 4.9 from a member here for the front and this would totally ROCK if I could get this to work for the rear. Is the only way to use these parts to take the axle and weld my brackets on to it and bolt up the entire swapped axle to my pathy. I've been searching and found this it kinda helps. http://forums.nicoclub.com/all-you-needed-to-know-about-nissan-axles-through-2004-t233955.html Does anyone out there know their xterra's well enough to help me with this? Thanks everyone! -Colby
  13. Status updates?? Sheesh I think I've been in a cave......
    1. Show previous comments  1 more
    2. nunya
      nunya
      you have...
    3. Der_Vier
      Der_Vier
      dirkadirkadirka!
    4. colbywan
      colbywan
      Been very busy but now I'm BACK!! Miss me?? lol
  14. I've got to agree with you there Nige!
  15. I know what you mean. I spent days effin with mine. I was almost positive they were equal height.
  16. Okay, guess I should trust my gut more often. I just start to over think things ya know. It's funny cause I noticed the front first. Then I noticed the rear looked worse so I started thinking maybe it was the culprit. It drives like total crap this way that's for sure. -Colby
  17. Ya know Adam, I was thinking that too kinda because the guy who did my alignment said my torsion bars were off (and I was like what the? because I was pretty dang sure they were even) and so he adjusted one. But the way it makes the rear look I just keep going back to the idea that it can't be the front bringing down the rear that much. But who knows hopefully it is. I made an appointment ot go back to the alignment guy Tue @ 9 so we'll see what he says. -Colby
  18. I just noticed that my pathfinder is leaning big time to the passenger side. I first thought it was the front end but the more I looked into it I'm thinking it is in the rear passenger side. I've got JGC coils that I've had for a long time and I was thinking maybe that one side is just sagging from being old and over used ya know so I pulled them both out marked them then swapped them to the opposite side. The sag / lean in still there on the same side??? I just had the alignment done and told them to check every bushing ball joint and maintanable part. They said everything was great. I had all the rear trailing arm bushings replace about a year or so ago and I've replaced just about everything imaginable in front. My frame doesn't appear to have any frame rot at all. The spring hats looked fine, I can't find any evidence of a broken part any where under there. I'm at a loss, the only thing I can think of is that maybe the frame is bent? But I looked at the frame over and over and it looks fine and there are no indications of a bend or anything like that. IDEAS!? This is a pic from my cell phone. I can get better pics if needed. I measured the difference between the drive side rear and passenger side rear and it's close to just under 2". -Colby
  19. Are you serious?? The round aluminum dial used to adjust the computer broke just like mine, wow what a coincedence! I would've thought it was a one in a million thing there but I guess more like a 2 in a million haha. How did you fix it, just replace ECU? -Colby
  20. Thanks for all the support fellas! I'd like to think that anyone of us in that same scenario would've done the same thing. Tungsten - Great idea, I had thought of that as a possibility as well. GG - I will do just that as soon as I get back from Alaska. I'm leaving tomorrow @ 3 for a week long fishing excursion. I'm so excited I can't even tell ya. -Colby
  21. I had contemplated getting only a new resistor but the circuit board looks pretty burnt and the resistor is far to burned to read what ohm and watt it was. I figured I'd get a new ECU and keep this one as a back up. -Colby
  22. Okay, well I decide to take the family on a little up in the mountains excursion using with our little pup (pop up trailer). I did everything I thought I could do to prepare for an mild off road trip. I changed the oil, put better tires up front, had the alignment fixed (again!!), got the truck inspected and passed emissions blah blah blah, checked all fluids, changed the air filter, filler her up with PREMIUM, and I even washed the ol girl. So I thought everything was golden. I decided since it was my first trip with the pup I had better take a bunch of tools for whatever I could foresee ya know. Everything is going great, the truck is towing better than normal. We get to the cabin camp for a night drop the trailer and decide to run to town for some baby stuff. On our way back about half way up the dirt road to the cabin while driving over a real bad washboard the truck just dies. Great no phone service here either. I start trying to eliminate the possible issues. First I check all fuses. They're all great. Then I check for spark, seems like there isn't any at all. I decided to check for fuel pressure too just for the heck of it and that definitely wasn't the problem. So I started thinking, hmm what could cause a lack of spark. The coil gone bad or what? Then I realized this fowl smell emanating from the cabin coming from directly under the passenger front seat. Uh oh that doesn't smell good, it smells just like burnt electronics and if any of you have ever smelled this it is VERY distinct and unmistakable. And we all know what resides under the front passenger seat, the ECU. So by now my wife and 11 month old baby have just been picked up by some very nice folks to be take back to camp (no phone service) and to get help from the fam. I decided since I'm stuck might as well take the seat out and see if I can see anything obviously wrong with the computer. Nope I can't see a thing except that I am now 100% positive that that is where the smell is coming from. By now a couple uncles show up and tow me back up the hill to camp, there I decide to delve deeper into the heart of the ECU and this is what I found. A fried resistor!! Oh shi#!! You'll never in a million years guess why there is a fried resistor either. Well I'll tell ya, a long long long time ago I noticed that the little toggle switch used to check and clear codes half of it kind of fell off or for some reason went missing. I had no idea it fell inside. It must've had the perfect storm of bounces from the washboardy road sending it flying right into the perfect spot to short out the ECU. I think it landed on one half of that load resistor and the other half of a diode that has a + connector right by it. Anyways that is what happened causing the ECU to stop functioning all together. So now I'm thinking I am really screwed. The truck is dead, I'm up here a couple hundred miles away with the family and a pup trailer. I mean talk about weird luck, the ECU basically fried itself I mean that piece had been in there forever ya know. So I'm thinking about how to get a new ECU and how to get one fast so I didn't miss work on Monday and I'm coming up blank. So I thought well maybe there's a possibility I can fix it? So I rip it out of the truck and start tinkering. I thought hmm I wonder if I could just jump a wire over the burnt part and at least get it running I mean what's the worst that could happen, fry the ECU worse?? So I cut a piece of wire from the trailer and splice it in the bypass the burnt part put the ECU back under the seat and get in then VIOLA! It FREAKING WORKED! No way, I can't believe that I actually got it running lol. Isn't that crazy?? That it actually was okay with bypassing the part it fried I mean I could've been so much more effed. So I ended up driving it all the way back and for 3 days til I got a new one lol! In fact I can't tell any difference what so ever, although i'm sure this isn't a permanent fix. I would imagine it would eventually fail due to the over voltage from the lack of load resistor. Here's a couple pics.
  23. Hey that thing looks familiar. Yeah I tow that trailer everyday about 25 miles each way. The pathy does pretty ok it's the headwinds that kill the ol girl haha otherwise it does round 70+ no prob. I haven't noticed any problems what so ever from the supposed short wheel base. I thought the wheel base was just fine for towing I mean it's not going to do well with a huge load but what SUV does aren't bigger trucks for that kinda stuff. As long as your realistic it's just fine for towing. Plus my pathy has 32's a heavy as hell bumper a wind brake safari style rack a speaker box and eveything else I lug around and that trailer isn't empty I'll say that much. I'd say it's somewhere over 2000 lbs at least with all my painting / remodeling gear inside. -Colby
  24. Congrats man a well deserved win. You've worked on your pathy and now you reap the rewards! -Colby
