So update on this situation. I had the pathfinder in OD when i towed my fiances Highboy its a 74 so very heavy. Also I made a mistake on the actual mph. Its slipping going from 1st to 2nd. I will check for punctured lines tomorrow It does have an aftermarket cooler installed. (thanks to you're amazing forums i was able to figure that out.) At 10 mph its shooting up to 4-5k and acting like its in neutral. I also believe that whoever drained the trans fluid last did a terrible job of it as the pan is covered in trans fluid on the outside. I believe i may need to replace the gasket. I took it around the neighborhood with OD off and it was running a little better. max speed i went was 35 the issue is persisting though. I'm really hoping someone can give me some good news as far as not having to replace or rebuild my trans. As im a pretty broke college student. The trans fluid is light pink although i believe it may be a little low its not pink all the way up to the checkered part of the dip. Also I'd like to thank everyone trying to help me with this issue and putting up with my inexperience. I also apologize for the amount im posting but ive wanted this rig since i was 15. I have not checked the MAF I will also do that tomorrow. and update as to the situation. I have pictures of the fluid pan exterior but have no idea how to post them so if anyone can advise me on how to post pictures Id appreciate it. Maybe posting pictures will give someone a better idea as to whats actually going on.
