4
Everything posted by mechanicalbaron
Snow blind. Sent from my SM-G920V using Tapatalk
NOX failure - Colorado Emissions
mechanicalbaron replied to jonrdory's topic in 96-2004 R50 Pathfinders
Interesting, did they give you a printout of the readings? Can you take a pic of it to look at all the numbers? I'm assuming you have similar emissions testing like here in California. Sent from my SM-G920V using Tapatalk -
There should be a small metal pipe that connects to the hose on the bottom of the egr back pressure transducer. Did you remove it and clean the orifice and blow through it? Pretty common for those to be plugged and that hose to be rotted. Sent from my SM-G920V using Tapatalk -
Bike Lane. Sent from my SM-G920V using Tapatalk
mechanicalbaron replied to RedRider3141's topic in The Garage
I've had similar thoughts. Always get hung up with the parking brake. Would love to see a thread on this. Sent from my SM-G920V using Tapatalk -
What are thinking? Had similar thoughts about a center console using an ammo can. Sent from my SM-G920V using Tapatalk -
1. The manufacturer has your vehicle towing capacity. Find out what it is. 2. Boat trailers have surge brakes. Electric brakes and water don't mix. 3. Regardless, if you want a 7 pin trailer harness, put one in. You can get an adapter to operate a 4 pinion harness. 4. If you decide to go with a 7 pin harness you will need a brake controller. I like prodigy. 5. Last but not least, utilize all of your resources to determine what will work for you. Sent from my SM-G920V using Tapatalk
Pop culture. Sent from my SM-G920V using Tapatalk
Put a new starter in her, the original one finally gave up. Only had about 186k mi. and 26 years on it. Think I'm gonna call Nissan consumer affairs and complain. Maybe I can get reimbursed. Sent from my SM-G920V using Tapatalk -
Snow angel Sent from my SM-G920V using Tapatalk
Horse trading Sent from my SM-G920V using Tapatalk
Lazy days. Sent from my SM-G920V using Tapatalk
New ignition switch and front door lock cylinders with new outer door handles. EBAY parts but all worked very well. Sent from my SM-G920V using Tapatalk -
Just last week saw the same issue on a Versa, the main difference being that with an electronic throttle body it was going into a brake over-ride causing a hesitation. Caught it when I was driving it and noticed that the running lights came on when applying the brakes. Doesn't happen often. Sent from my SM-G920V using Tapatalk
Truly amazing. Sent from my SM-G920V using Tapatalk
Big man. Sent from my SM-G920V using Tapatalk
Sand wash Sent from my SM-G920V using Tapatalk
When your offroading with some buddies and they say " dude, I can't believe you made it through that!" Sent from my SM-G920V using Tapatalk
07 to 12 Altima's are great cars. The only real issue's I've seen with them are stop lamp switches and that doggone CVT trans. At least the trans has a 10/120 warranty. Sent from my SM-G920V using Tapatalk
Dream car. Sorry, had to bypass you Mr. RoguePathy. Sent from my SM-G920V using Tapatalk
Washed the mud off it, vacuumed her out, lubed the hood latch, removed the turn/headlamp switch and cleaned the contacts, and replaced both headlamp bulbs. Sent from my SM-G920V using Tapatalk -
Looking a little bit into your year model, it appears that there should be a fog light there. Mines different. When in doubt Google it. Sent from my SM-G920V using Tapatalk
Factory fog lights are mounted under the bumper directly below the turn signals. The brackets for them are bolted to the core support. Sent from my SM-G920V using Tapatalk
The windows are just based off mine when I got it, pulled off the rear door panels and found the regulators locked in the upper position using screws. Best to actually check for power and ground at the motor itself. I have a running light socket and bulb I use on stuff like that to verify power and the ability of the circuit to carry the load. A three jaw puller should work on the crank pulley, I have a special one at work that uses the threaded holes in the pulley, I'll try to get a pic of that setup tomorrow. My recommendation on the front end bushings and stuff is mainly due to having to take so much apart just to do one thing, if you are going to do ball joints you may as well do all the bushings. I got a set of polyurethane bushings for about $40 for the upper and lower arms, way cheaper and easier than replacing with rubber ones. Downfall being they are noisy. With mine is pulled out both of my door lock cylinder and liberally sprayed WD40 into them and worked them with the key. Was able to get them both to work. I'm pretty sure you can get a full lockset from the dealership with both door lock cylinders, ignition cylinder and keys, but that's gonna cost some cash. Sent from my SM-G920V using Tapatalk
Alignment, a dealership doesn't necessarily need to do it, however alignments are tough on these. I would recommend replacing the upper control arms bushings, lower control arm bushings, radius arm bushings, steering center link and upper and lower ball joints. Likely they are all worn, but inspect them and make sure they are bad before you replace them . If everything is OK in the front end then find a reputable place to do your alignment. Sent from my SM-G920V using Tapatalk
